주요 콘텐츠로 건너뛰기
Motorola Moto G4 Play Screen Replacement
필요한 것
  1. Motorola Moto G4 Play Screen Replacement, Remove back plate: 1 단계, 이미지 1/1
    • Remove back plate starting with this tab
  2. Motorola Moto G4 Play Screen Replacement: 2 단계, 이미지 1/1
    • remove battery
    • remove SD card and sim card
  3. Motorola Moto G4 Play Screen Replacement, remove screws and inner back plate: 3 단계, 이미지 1/2 Motorola Moto G4 Play Screen Replacement, remove screws and inner back plate: 3 단계, 이미지 2/2
    • remove 16 phillips 00 screws
    • the two screws on either side of the battery (red color on thread) are shorter than the other screws (blue color on thread)
    • don't forget this one hiding underneath this sticker
    • no screw here
    • remove the inner back plate
  4. Motorola Moto G4 Play Screen Replacement, Remove the motherboard: 4 단계, 이미지 1/3 Motorola Moto G4 Play Screen Replacement, Remove the motherboard: 4 단계, 이미지 2/3 Motorola Moto G4 Play Screen Replacement, Remove the motherboard: 4 단계, 이미지 3/3
    • disconnect antenna cable from motherboard with a spudger.
    • disconnect screen and digitiser cables with a spudger.
    • remove rear facing camera with a spudger
    • remove phillips 00 screw
    • Remove motherboard. this cable is still connected, you must disconnect it as you remove the motherboard.
    • There is a cable attached to the bottom of the motherboard, be careful when removing it
  5. Motorola Moto G4 Play Screen Replacement, Remove USB accessory board: 5 단계, 이미지 1/2 Motorola Moto G4 Play Screen Replacement, Remove USB accessory board: 5 단계, 이미지 2/2
    • disconnect antenna and data cable
    • remove philips 00 screws
    • Remove usb board and vibrator together.
    • vibrator is attached to usb board from the bottom, be careful and remove them together to prevent damage.
  6. Motorola Moto G4 Play Screen Replacement, Remove remaining components from screen assembly: 6 단계, 이미지 1/2 Motorola Moto G4 Play Screen Replacement, Remove remaining components from screen assembly: 6 단계, 이미지 2/2
    • Peel off black sticker under battery compartment.
    • peel off data cable
    • remove antenna wire
    • remove speaker
결론
다른 9명이 해당 안내서를 완성하였습니다.
Michael Cottone
회원 가입일: 09/09/17
930 평판
안내서 2개 작성하였습니다
Cottone Computing Cottone Computing 회원
Business
1 회원
안내서 2개 작성하였습니다
댓글 3개
what if the new screen does not turn on or light up when you turn the phone on??? what part is causing that issue??
lilmizzipf - 답글
I’ve just wrapped up an abortive attempt to replace the screen on a friend’s G4 Play. It was aborted because the screen I bought off of ebay has only one digitizer connection on the upper left of the screen but my friend’s model has the two connections pictured in step 4 of this procedure. I can’t find an XT1601 screen on ebay or aliexpress or anywhere else that sports the twin connectors. What model of phone was this? Any clues on how to track this down?
jrhooker - 답글
@jrhooker that’s the button cable
benjamin linne - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 15
전체 시간: 5,685
