주요 콘텐츠로 건너뛰기
Motorola Moto G4 Play Screen Replacement
필요한 것
  1. Motorola Moto G4 Play Screen Replacement, Battery: 1 단계, 이미지 1/3 Motorola Moto G4 Play Screen Replacement, Battery: 1 단계, 이미지 2/3 Motorola Moto G4 Play Screen Replacement, Battery: 1 단계, 이미지 3/3
    • Open case with a plastic opening tool that has the same size as the divot located at the bottom left of the phone. If you don’t have an opening tool, use your finger nails.
  2. Motorola Moto G4 Play Screen Replacement: 2 단계, 이미지 1/3 Motorola Moto G4 Play Screen Replacement: 2 단계, 이미지 2/3 Motorola Moto G4 Play Screen Replacement: 2 단계, 이미지 3/3
    • Lift the case by the nearest corner to the divot and remove it from the phone.
  3. Motorola Moto G4 Play Screen Replacement: 3 단계, 이미지 1/3 Motorola Moto G4 Play Screen Replacement: 3 단계, 이미지 2/3 Motorola Moto G4 Play Screen Replacement: 3 단계, 이미지 3/3
    • Place the plastic opening tool into the notch located at the bottom of the battery compartment, and lift upwards. If you don’t have an opening tool, use your finger nails.
    • Remove battery from your phone.
  4. Motorola Moto G4 Play Screen Replacement, Midframe: 4 단계, 이미지 1/3 Motorola Moto G4 Play Screen Replacement, Midframe: 4 단계, 이미지 2/3 Motorola Moto G4 Play Screen Replacement, Midframe: 4 단계, 이미지 3/3
    • Remove any SIM card and/or memory card present using your hand.
  5. Motorola Moto G4 Play Screen Replacement: 5 단계, 이미지 1/2 Motorola Moto G4 Play Screen Replacement: 5 단계, 이미지 2/2
    • Remove the small silicon cover at the bottom right of the camera using tweezers.
  6. Motorola Moto G4 Play Screen Replacement: 6 단계, 이미지 1/1
    • Remove the sixteen (16) 3mm Phillips PH000 screws securing the midframe.
    • Some phones have two shorter screws, one on each side of the battery (double marked with orange circles at left). If your device has these shorter screws, make sure they go back in their original holes.
  7. Motorola Moto G4 Play Screen Replacement: 7 단계, 이미지 1/3 Motorola Moto G4 Play Screen Replacement: 7 단계, 이미지 2/3 Motorola Moto G4 Play Screen Replacement: 7 단계, 이미지 3/3
    • Remove the back panel assembly with your hands.
  8. Motorola Moto G4 Play Screen Replacement, Rear Camera: 8 단계, 이미지 1/3 Motorola Moto G4 Play Screen Replacement, Rear Camera: 8 단계, 이미지 2/3 Motorola Moto G4 Play Screen Replacement, Rear Camera: 8 단계, 이미지 3/3
    • Use the flat end of a spudger to disconnect the rear-facing camera connector from its socket on the mother board.
  9. Motorola Moto G4 Play Screen Replacement: 9 단계, 이미지 1/1
    • After detaching the connector, carefully remove the camera using tweezers. If you don't have tweezers, use your hands.
  10. Motorola Moto G4 Play Screen Replacement, Charging Port: 10 단계, 이미지 1/2 Motorola Moto G4 Play Screen Replacement, Charging Port: 10 단계, 이미지 2/2
    • Use tweezers to pop up the antenna wire.
  11. Motorola Moto G4 Play Screen Replacement: 11 단계, 이미지 1/2 Motorola Moto G4 Play Screen Replacement: 11 단계, 이미지 2/2
    • Use the flat end of a spudger to pry up on the connector at the bottom of the battery space.
  12. Motorola Moto G4 Play Screen Replacement: 12 단계, 이미지 1/1
    • Remove the two (2) 3mm Phillips PH000 screws securing the charging port.
  13. Motorola Moto G4 Play Screen Replacement: 13 단계, 이미지 1/3 Motorola Moto G4 Play Screen Replacement: 13 단계, 이미지 2/3 Motorola Moto G4 Play Screen Replacement: 13 단계, 이미지 3/3
    • Insert the tweezers under the vibrator and gently lift up the whole part.
  14. Motorola Moto G4 Play Screen Replacement: 14 단계, 이미지 1/3 Motorola Moto G4 Play Screen Replacement: 14 단계, 이미지 2/3 Motorola Moto G4 Play Screen Replacement: 14 단계, 이미지 3/3
    • Pop up on the vibrator's connector to separate it from the charging port.
  15. Motorola Moto G4 Play Screen Replacement, Screen: 15 단계, 이미지 1/3 Motorola Moto G4 Play Screen Replacement, Screen: 15 단계, 이미지 2/3 Motorola Moto G4 Play Screen Replacement, Screen: 15 단계, 이미지 3/3
    • Using an opening tool, pry up one of the connectors to the left of where the sim card was located.
  16. Motorola Moto G4 Play Screen Replacement: 16 단계, 이미지 1/3 Motorola Moto G4 Play Screen Replacement: 16 단계, 이미지 2/3 Motorola Moto G4 Play Screen Replacement: 16 단계, 이미지 3/3
    • Pry up the next connector located right on top of the previous one.
  17. Motorola Moto G4 Play Screen Replacement: 17 단계, 이미지 1/3 Motorola Moto G4 Play Screen Replacement: 17 단계, 이미지 2/3 Motorola Moto G4 Play Screen Replacement: 17 단계, 이미지 3/3
    • Using the Phillips screwdriver, remove the screw that's found next to the speaker on the top left of the phone.
  18. Motorola Moto G4 Play Screen Replacement: 18 단계, 이미지 1/3 Motorola Moto G4 Play Screen Replacement: 18 단계, 이미지 2/3 Motorola Moto G4 Play Screen Replacement: 18 단계, 이미지 3/3
    • Using the plastic opening tool, carefully pry up the motherboard.
  19. Motorola Moto G4 Play Screen Replacement: 19 단계, 이미지 1/2 Motorola Moto G4 Play Screen Replacement: 19 단계, 이미지 2/2
    • Pull up the cable that connects the motherboard and the charging port.
    • It's on the side that's closer to the motherboard, you might need to push the cable down first, and then pull it up.
  20. Motorola Moto G4 Play Screen Replacement: 20 단계, 이미지 1/3 Motorola Moto G4 Play Screen Replacement: 20 단계, 이미지 2/3 Motorola Moto G4 Play Screen Replacement: 20 단계, 이미지 3/3
    • Pry up the frontal speaker with a plastic opening tool.
  21. Motorola Moto G4 Play Screen Replacement: 21 단계, 이미지 1/3 Motorola Moto G4 Play Screen Replacement: 21 단계, 이미지 2/3 Motorola Moto G4 Play Screen Replacement: 21 단계, 이미지 3/3
    • Peel the black tape up with a plastic opening tool and or your fingers.
  22. Motorola Moto G4 Play Screen Replacement: 22 단계, 이미지 1/3 Motorola Moto G4 Play Screen Replacement: 22 단계, 이미지 2/3 Motorola Moto G4 Play Screen Replacement: 22 단계, 이미지 3/3
    • Peel the flexible black cable using a plastic opening tool and or your fingers.
  23. Motorola Moto G4 Play Screen Replacement: 23 단계, 이미지 1/3 Motorola Moto G4 Play Screen Replacement: 23 단계, 이미지 2/3 Motorola Moto G4 Play Screen Replacement: 23 단계, 이미지 3/3
    • Peel up the small tape that's connected to the screen with a plastic opening tool.
  24. Motorola Moto G4 Play Screen Replacement: 24 단계, 이미지 1/2 Motorola Moto G4 Play Screen Replacement: 24 단계, 이미지 2/2
    • Place an iOpener on the edges to soften the screen adhesive.
  25. Motorola Moto G4 Play Screen Replacement: 25 단계, 이미지 1/3 Motorola Moto G4 Play Screen Replacement: 25 단계, 이미지 2/3 Motorola Moto G4 Play Screen Replacement: 25 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    구매
    • Insert the Jimmy knife through the edge.
    • Place a plastic card so that the adhesive doesn't stick back again.
    • Go around the edges of the device with the Jimmy knife until all the adhesive has been removed.
  26. Motorola Moto G4 Play Screen Replacement: 26 단계, 이미지 1/3 Motorola Moto G4 Play Screen Replacement: 26 단계, 이미지 2/3 Motorola Moto G4 Play Screen Replacement: 26 단계, 이미지 3/3
    • Pull up on the LCD screen with your hands and remove it.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Yordan Gil
회원 가입일: 02/14/18
426 평판
안내서 1개 작성함
USF Tampa, Team S17-G4, Boczar Spring 2018 USF Tampa, Team S17-G4, Boczar Spring 2018 회원
USFT-BOCZAR-S18S17G4
4 회원들
안내서 11개 작성하였습니다
댓글 4개
The phone I just tried to fix had two digitizer connectors just like the one in this procedure, but all the replacement parts I can find on ebay and aliexpress etc. which claim to be for XT1601 - XT1609 have just a single connector. Any thoughts about why that would be?
jrhooker - 답글
The smaller one is from the power and Volume buttons and needs tobe transfered to the new display if you bought one with Frame (which makes it much easier)
Marko Käppler - 답글
I had to figure out that out myself. Yes, you will need to transfer the connector from the old frame to the new frame. I should also add, the frame I got had no buttons, so I had to get them from the old phone.
Joshua Rieth -
Good guide though I could not see the purpose of removing items 20, 21 & 22
pauldmallett - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 14
전체 시간: 4,662
