메인 콘텐츠로 스킵하기
소개
Motorola Moto G4 Plus is Moto G Plus (4th Gen) released in 2016.This video shows you how to teardown/disassemble Motorola Moto G4 Plus completely. It also shows how to repairing back cover, rear housing, loudspeaker, headphone jack and other components. Why don’t you replace it by yourself according to this replacement tutorial?
부품
지정된 부품이 없습니다.
Video Instructions
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
맥북 배터리 수리 키트
기본 가격은 $69.99
Buy Now
결론
다른 6명이 해당 안내서를 완성하였습니다.
Witrigs
회원 가입일: 2015년 11월 24일
61,446 평판
안내서 387개 작성하였습니다
What about the digitiser? This video stops before showing how it can be removed
Stephane Barbier - 답글
lcd with digitizer are combined together with glue, it is difficult to replace front digitizer only, if you have broken front glass, you need to replace full front screen including lcd with digitizer, Moto g4 plus lcd screen repair guide is available later today, you can follow it here: https://www.youtube.com/watch?v=6qdwuU0o...
Witrigs - 답글
What about the USB port? It's still attached to the motherboard in this video.
Matthew - 답글
It's difficult to remove it. Need to do a micro welding to replace the USB port.
Witrigs -
Is all that tape necessary to keep or can it be discarded?
Christopher Pan - 답글
You had better keep them all and put then back when reassemble.
Witrigs -
Note - I was able to disassemble using Torx T4, not T3
Gerry Fahy - 답글
Use a good quality tool kit, such as the iFixit Mako 64 bit set from Pimeroni
ttps://shop.pimoroni.com/products/ifixit-64-bit-driver-kit
Ensure that the T3 bit is fully located in the screw head - light pressure, slight twist to locate, push in and maintain pressure while turning. If the bit is not properly located then you risk striping the screw head or driver.
stage2video -
The screws are really tight, after several attemps ive only did one, the rest seem impossible to unscrew. Im using a T3 type as recommended, any advice?
Karl - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 47
지난 30일: 195
전체 시간: 18,958
