주요 콘텐츠로 건너뛰기
Motorola Moto G5 Battery Replacement
필요한 것
  1. Motorola Moto G5 Battery Replacement, Back Cover: 1 단계, 이미지 1/2 Motorola Moto G5 Battery Replacement, Back Cover: 1 단계, 이미지 2/2
    • Insert your fingernail or the flat end of a spudger into the notch on the bottom edge of the phone near the charging port.
    • Pry with your fingernail or twist the spudger to release the back cover from the phone.
  2. Motorola Moto G5 Battery Replacement: 2 단계, 이미지 1/3 Motorola Moto G5 Battery Replacement: 2 단계, 이미지 2/3 Motorola Moto G5 Battery Replacement: 2 단계, 이미지 3/3
    • Insert the flat end of a spudger into the seam and slide it along the bottom edge to release the clips holding the back cover to the phone.
  3. Motorola Moto G5 Battery Replacement: 3 단계, 이미지 1/3 Motorola Moto G5 Battery Replacement: 3 단계, 이미지 2/3 Motorola Moto G5 Battery Replacement: 3 단계, 이미지 3/3
    • Continue sliding the flat end of the spudger along the seam for the remaining sides of the phone.
  4. Motorola Moto G5 Battery Replacement: 4 단계, 이미지 1/2 Motorola Moto G5 Battery Replacement: 4 단계, 이미지 2/2
    • Lift the back cover and remove it from the phone.
    • To reinstall the back cover, align the cover with the phone and squeeze along the edges to snap the clips back into place.
  5. Motorola Moto G5 Battery Replacement, Battery: 5 단계, 이미지 1/2 Motorola Moto G5 Battery Replacement, Battery: 5 단계, 이미지 2/2
    • Insert your fingernail or the flat end of the spudger into the notch below the battery.
    • Pry with your fingernail or spudger until you free the battery from its recess.
  6. Motorola Moto G5 Battery Replacement: 6 단계, 이미지 1/1
    • Remove the battery.
    • When installing the battery, make sure the battery's contacts line up with the three gold pins on the top right.
결론
After completing this guide, calibrate your newly-installed battery.
Repair didn’t go as planned? Check out our Motorola Moto G5 Answers community for troubleshooting help.
다른 9명이 해당 안내서를 완성하였습니다.
Arthur Shi
회원 가입일: 01/03/18
252,690 평판
안내서 526개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 5개
this is not the g5 replacement procedure. it will not work.need to remove screen.
Tom Tercek - 답글
@Tom Tercek - You are in a huge mistake. This is the Motorola Moto G5 phone and the battery is removable and as shown on the pics, very easy to replace.
prishylets - 답글
is it also possible with moto g5s?
Jojo Blublub - 답글
Unfortunately, the G5S does not have an easily replaceable battery.
Arthur Shi -
Hi, I'm looking for parts for Moto G5, specifically an intern plastic cover that goes over the charge port.
Leonardo - 답글
댓글 쓰기
조회 통계:
24 시간 전: 14
7일 전: 96
30일 전: 457
전체 시간: 39,148
