주요 콘텐츠로 건너뛰기
Motorola Moto G5 Rear Facing Camera Replacement
필요한 것
  1. Motorola Moto G5 Rear Facing Camera Replacement, Back Cover: 1 단계, 이미지 1/2 Motorola Moto G5 Rear Facing Camera Replacement, Back Cover: 1 단계, 이미지 2/2
    • Insert your fingernail or the flat end of a spudger into the notch on the bottom edge of the phone near the charging port.
    • Pry with your fingernail or twist the spudger to release the back cover from the phone.
  2. Motorola Moto G5 Rear Facing Camera Replacement: 2 단계, 이미지 1/3 Motorola Moto G5 Rear Facing Camera Replacement: 2 단계, 이미지 2/3 Motorola Moto G5 Rear Facing Camera Replacement: 2 단계, 이미지 3/3
    • Insert the flat end of a spudger into the seam and slide it along the bottom edge to release the clips holding the back cover to the phone.
  3. Motorola Moto G5 Rear Facing Camera Replacement: 3 단계, 이미지 1/3 Motorola Moto G5 Rear Facing Camera Replacement: 3 단계, 이미지 2/3 Motorola Moto G5 Rear Facing Camera Replacement: 3 단계, 이미지 3/3
    • Continue sliding the flat end of the spudger along the seam for the remaining sides of the phone.
  4. Motorola Moto G5 Rear Facing Camera Replacement: 4 단계, 이미지 1/2 Motorola Moto G5 Rear Facing Camera Replacement: 4 단계, 이미지 2/2
    • Lift the back cover and remove it from the phone.
    • To reinstall the back cover, align the cover with the phone and squeeze along the edges to snap the clips back into place.
  5. Motorola Moto G5 Rear Facing Camera Replacement, Battery: 5 단계, 이미지 1/2 Motorola Moto G5 Rear Facing Camera Replacement, Battery: 5 단계, 이미지 2/2
    • Insert your fingernail or the flat end of the spudger into the notch below the battery.
    • Pry with your fingernail or spudger until you free the battery from its recess.
  6. Motorola Moto G5 Rear Facing Camera Replacement: 6 단계, 이미지 1/1
    • Remove the battery.
    • When installing the battery, make sure the battery's contacts line up with the three gold pins on the top right.
  7. Motorola Moto G5 Rear Facing Camera Replacement, Rear Facing Camera: 7 단계, 이미지 1/2 Motorola Moto G5 Rear Facing Camera Replacement, Rear Facing Camera: 7 단계, 이미지 2/2
    • Remove the eight (8) 4mm screws with a Phillips screwdriver.
  8. Motorola Moto G5 Rear Facing Camera Replacement: 8 단계, 이미지 1/3 Motorola Moto G5 Rear Facing Camera Replacement: 8 단계, 이미지 2/3 Motorola Moto G5 Rear Facing Camera Replacement: 8 단계, 이미지 3/3
    • Pry the top motherboard cover off using a plastic opening tool.
    • When prying it open, make sure to pry it around evenly so that the cover will not snap. This will require some force.
  9. Motorola Moto G5 Rear Facing Camera Replacement: 9 단계, 이미지 1/3 Motorola Moto G5 Rear Facing Camera Replacement: 9 단계, 이미지 2/3 Motorola Moto G5 Rear Facing Camera Replacement: 9 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Disconnect the marked connector with a pair of tweezers and remove the camera piece.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Kristina Tran
회원 가입일: 01/24/18
565 평판
안내서 2개 작성하였습니다
Cal Poly, Team S2-G3, Livingston Winter 2018 Cal Poly, Team S2-G3, Livingston Winter 2018 회원
CPSU-LIVINGSTON-W18S2G3
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 22
전체 시간: 1,777
