소개
The Motorola Moto G6, like most phones, houses a motherboard that connects all of the components of the device and controls its subsystems. In order to remove many of the Moto G6’s commonly-replaced components, the motherboard must be removed first. Use this guide to successfully take the motherboard out of your Moto G6.
No repair experience is required. However, this replacement will require tools to remove the needed components of the device. The specific device model in this guide is XT1925-12. Other model numbers include: XT1925-4, XT1925-5, XT1925-6, and XT1925DL.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Before beginning the repair, make sure the device is turned off and disconnected from an external power source. Gather the suggested tools listed below.
필요한 것
If possible, drain the battery before disassembly. When the battery is charged, there's an increased risk of a dangerous thermal event if the battery is overheated or damaged during repairs.
Prepare an iOpener and heat the back of the phone along its bottom edge for about two minutes, or until it's slightly too hot to touch. This will help soften the adhesive securing the rear glass.
Apply a suction cup to the bottom edge of the rear glass.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the rear glass and the frame.
If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools quickly, so you may need to heat it repeatedly.
Insert an opening pick into the gap you created under the rear glass.
My back delaminated at this point. That is, the clear plastic started to come away leaving the paint layer behind. Mine is (was) the indigo blue one.
이 단계에 사용된 도구:Tesa 61395 Tape$5.99
If the glass remains stuck, re-heat and slice the adhesive repeatedly as needed.
Lift the rear glass carefully, making sure it's fully separated from any adhesive.
Remove the rear glass.
When cleaning old adhesive off the back glass, be careful not to scratch the inner coating of the glass. If you scratch this coating with tweezers, it will leave visible “nicks” on the back glass.
Use a pair of tweezers to carefully peel up the black tape covering the battery.
Remove the tape.
Yes, there's the NFC tag that isn't mentioned, with its connection to the left. Thanks for the tip, Stuart; I gently lifted mine to the left and it seems to be intact. I guess I won't know until I try to pay for something.
Use a Phillips driver to remove seventeen screws securing the plastic cover:
Eleven grey 3 mm-long screws
Five black 2.5 mm-long screws
One silver 3.5 mm-long screw
The holes for the black screws are marked with a small triangle to differentiate them from the holes for the gray ones. I found this super helpful when reassembling!
Jamie Bell - 답글
Insert the pointed end of a spudger into the notch at the top left edge of the plastic cover.
Pry up with the spudger to lift the upper edge of the cover and release the clips holding the cover down.
Remove the plastic cover.
When reinstalling plastic cover, alignment is critical for underlying contacts to line up. Test all functions before sealing up the phone. If camera or speaker don’t work, recheck plastic cover installation and correct until all phone functions operate.
Using the iFixit opening tool, pop up the three press-fit connectors in the bottom right corner of the motherboard.
Remove the motherboard out of place.
다른 4명이 해당 안내서를 완성하였습니다.
At what temperature shold the glass be heated to? My heat gun goes from 250 up to 1350.
Miles Raymond - 답글
START LOW.
These plastics can be almost endlessly remelted, held at temp, etc., if done gently.
With a heat gun, I'd hesitate to go too far past 250°F/115°C too quickly until I was comfortable with the material.
Plastic WILL begin to burn and permanently deteriorate at 350-400°F or so.
Silicone can handle up to 400-500°F.
(Get a cast iron pot or pan to roughly 250°F/110°C, then invert and put a silicone cookie sheet on it to make a work surface that will make life waaaaaay easier. Preheat the device along with the pan for a few minutes, too.)
Filthy Pazuzu - 답글
