주요 콘텐츠로 건너뛰기
Motorola Moto G7 Play Camera Replacement
필요한 것
  1. Motorola Moto G7 Play Camera Replacement, Back Cover: 1 단계, 이미지 1/2 Motorola Moto G7 Play Camera Replacement, Back Cover: 1 단계, 이미지 2/2
    • Turn off your device before you begin.
    • Use the iFixit pick to break the adhesive around the back case.
    • Use a heat gun, hairdryer, or iOpener to weaken the adhesive around the back case. If you're using the iOpener, please review the instructions for proper use.
  2. Motorola Moto G7 Play Camera Replacement: 2 단계, 이미지 1/1
    • Detach the back case from the phone.
    • Make sure the back is opened right to left so the cable of the fingerprint scanner does not get damaged.
  3. Motorola Moto G7 Play Camera Replacement: 3 단계, 이미지 1/2 Motorola Moto G7 Play Camera Replacement: 3 단계, 이미지 2/2
    • Use the iFixit pick and the iFixit opening tool to pull the fingerprint scanner off of the back case.
  4. Motorola Moto G7 Play Camera Replacement, Camera: 4 단계, 이미지 1/1
    • Remove the nine 3.2mm screws from the motherboard cover with a Phillips #00 screwdriver.
  5. Motorola Moto G7 Play Camera Replacement: 5 단계, 이미지 1/1
    • Lift the motherboard cover from the bottom.
    • Use reverse tweezers or a similar tool if needed.
  6. Motorola Moto G7 Play Camera Replacement: 6 단계, 이미지 1/2 Motorola Moto G7 Play Camera Replacement: 6 단계, 이미지 2/2
    • Once the motherboard cover is removed, use the iFixit opening tool to disconnect the ribbon cable connecting the camera to the motherboard.
    • The camera can now be removed and is ready to be replaced.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Monserath Casillas
회원 가입일: 02/10/20
1,146 평판
안내서 5개 작성하였습니다
Cal Poly, Team S7-G4, Regan Winter 2020 Cal Poly, Team S7-G4, Regan Winter 2020 회원
CPSU-REGAN-W20S7G4
5 회원들
안내서 12개 작성하였습니다
댓글 한 개
My camera stopped working after water damage. Replacing the camera itself didn’t fix it. What could the problem be?
abb - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 925
