소개
When the Motorola G7 Play, models XT1952-3 and XT1952-2, no longer charges, it could be due to a failing charging port. This replacement guide provides efficient steps to get the device working again. If replacing the charging port doesn’t fix the issue, attempt to replace the battery with this guide.
부품
지정된 부품이 없습니다.
Remove the six 3.2 mm screws from the charging port assembly cover with a Phillips #00 screwdriver.
다른 4명이 해당 안내서를 완성하였습니다.
댓글 한 개
Xt1952-4 is the same. Replaced the charge port due to microphone failing.
