소개
This is a fingerprint scanner replacement guide for the Motorola Moto G7 Play, specifically the XT1952-3 and XT1952-2. The fingerprint is an important feature for the device, as it helps provide extra security to keep files safe. If the device no longer unlocks when the sensor is touched, then it should be replaced.
부품
지정된 부품이 없습니다.
Remove the nine 3.2 mm screws from the motherboard cover with a Phillips #00 screwdriver.
다른 한 분이 해당 안내서를 완성하였습니다.
