주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
This motherboard replacement guide should be attempted if other parts of the device were replaced, but the problem persisted. The steps should be followed for the Motorola G7 Play, models XT1952-3 and XT1952-2. The motherboard powers the whole device and makes it function, so it’s a very important part that should be replaced if it is damaged.
  1. Turn off your device before you begin. Use the iFixit pick to break the adhesive around the back case.
    • Turn off your device before you begin.
    • Use the iFixit pick to break the adhesive around the back case.
    • Use a heat gun, hairdryer, or iOpener to weaken the adhesive around the back case. If you're using the iOpener, please review the instructions for proper use.
  2. Detach the back case from the phone.
    • Detach the back case from the phone.
    • Make sure the back is opened right to left so the cable of the fingerprint scanner does not get damaged.
  3. Use the iFixit pick and the iFixit opening tool to pull the fingerprint scanner off of the back case. Use the iFixit pick and the iFixit opening tool to pull the fingerprint scanner off of the back case.
    • Use the iFixit pick and the iFixit opening tool to pull the fingerprint scanner off of the back case.
  4. 필수 도구 키트
    최고의 소형 키트에서 가장 유용한 도구.
    지금 쇼핑하기
    필수 도구 키트
    지금 쇼핑하기
  5. Remove the nine 3.2mm screws from the motherboard cover with a Phillips #00 screwdriver.
    • Remove the nine 3.2mm screws from the motherboard cover with a Phillips #00 screwdriver.
  6. Lift motherboard cover off by the bottom.
    • Lift motherboard cover off by the bottom.
    • Use reverse tweezers or a similar tool if needed.
  7. Once the motherboard cover is removed, disconnect the four ribbon cables and the two wires attached to the motherboard. Once the motherboard cover is removed, disconnect the four ribbon cables and the two wires attached to the motherboard.
    • Once the motherboard cover is removed, disconnect the four ribbon cables and the two wires attached to the motherboard.
  8. Using the Phillips #00 screwdriver, remove the single 0.4 mm black screw in the center of the motherboard. Remove the motherboard from the device.
    • Using the Phillips #00 screwdriver, remove the single 0.4 mm black screw in the center of the motherboard.
    • Remove the motherboard from the device.
결론
Monserath Casillas
회원 가입일: 2020년 02월 10일
901 평판
안내서 5개 작성하였습니다
Cal Poly, Team S7-G4, Regan Winter 2020 Cal Poly, Team S7-G4, Regan Winter 2020 회원
CPSU-REGAN-W20S7G4
5 회원들
안내서 10개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 21
30일 전: 81
전체 시간: 845
