주요 콘텐츠로 건너뛰기
Motorola Moto G7 Plus Fingerprint Sensor Replacement
필요한 것
  1. Motorola Moto G7 Plus Fingerprint Sensor Replacement, Fingerprint Sensor: 1 단계, 이미지 1/2 Motorola Moto G7 Plus Fingerprint Sensor Replacement, Fingerprint Sensor: 1 단계, 이미지 2/2
    • Insert an opening pick under the screen, starting at the top of the phone.
    • Work the pick along the edges of the phone while placing them in the corners.
    • After placing the picks along the edge of the screen, refer to step 2.
    • Unlike the front of the phone, it is fine to use the picks on the left side of the phone because there are no cables that can be damaged.
    • While not necessary, applying a heat gun will weaken the adhesive, making this step significantly easier and quicker.
  2. Motorola Moto G7 Plus Fingerprint Sensor Replacement: 2 단계, 이미지 1/2 Motorola Moto G7 Plus Fingerprint Sensor Replacement: 2 단계, 이미지 2/2
    • Loosen the adhesive by cutting along the sides of the phone with the Jimmy Knife and prop open the back.
    • It is possible to use the opening pick to remove adhesive from the edges of the back case, however, it is much more difficult.
  3. Motorola Moto G7 Plus Fingerprint Sensor Replacement: 3 단계, 이미지 1/2 Motorola Moto G7 Plus Fingerprint Sensor Replacement: 3 단계, 이미지 2/2
    • The fingerprint sensor is now visible and can be replaced.
    • Remove the sensor cable with the metallic cover on top.
    • No tools or screws are necessary to remove the cable as it should easily come right off.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Arun Ganesh
회원 가입일: 02/10/20
121 평판
안내서 1개 작성함
Cal Poly, Team S22-G5, Regan Winter 2020 Cal Poly, Team S22-G5, Regan Winter 2020 회원
CPSU-REGAN-W20S22G5
5 회원들
안내서 17개 작성하였습니다
댓글 3개
Hello, the connector of the fingerprint scanner isn’t actually detachable from the back. In order to reach it you need to take the screen off, so this tutorial is only partially helpful for fixing the fingerprint scanner.
Danny Remi - 답글
hello y need a original battery cover for my motorola moto g7 plus can you help me $g$
Miguel Plascencia guzman - 답글
Where can I order the sensor from?
Sourabh Kapur - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 29
전체 시간: 3,459
