주요 콘텐츠로 건너뛰기
Motorola Moto G7 Plus Front Camera Replacement
필요한 것
  1. Motorola Moto G7 Plus Front Camera Replacement, Remove the Screen: 1 단계, 이미지 1/2 Motorola Moto G7 Plus Front Camera Replacement, Remove the Screen: 1 단계, 이미지 2/2
    • Insert an opening tool pick under the screen, starting at the top of the phone.
    • Slide the pick around the entire perimeter of the display to break the adhesive.
    • There is a cable on the right side of the phone (the side with the volume buttons), which connects the screen to the rest of the phone. Be careful not to damage this cable.
    • Once enough adhesive has been removed, you should be able to separate the screen by gently lifting it from the left side of the phone.
    • While not necessary, applying a gentle heat to the edges of the display with a heat gun or iOpener will weaken the adhesive.
  2. Motorola Moto G7 Plus Front Camera Replacement, Remove the Display Cable Cover: 2 단계, 이미지 1/2 Motorola Moto G7 Plus Front Camera Replacement, Remove the Display Cable Cover: 2 단계, 이미지 2/2
    • Remove the three 2.7 mm screws that surround the base of the display cable using the Torx T5 screwdriver.
    • Gently remove the metal piece that covers the base of the display cable.
  3. Motorola Moto G7 Plus Front Camera Replacement: 3 단계, 이미지 1/2 Motorola Moto G7 Plus Front Camera Replacement: 3 단계, 이미지 2/2
    • Use the pointed end of the spudger to lift the metal casing where circled.
  4. Motorola Moto G7 Plus Front Camera Replacement, Separate the Display From the Phone: 4 단계, 이미지 1/2 Motorola Moto G7 Plus Front Camera Replacement, Separate the Display From the Phone: 4 단계, 이미지 2/2
    • Underneath this metal piece is the base of the cable. Use a spudger to vertically lift the connection out of its port.
  5. Motorola Moto G7 Plus Front Camera Replacement, Front Camera: 5 단계, 이미지 1/1
    • Remove the eleven screws with the T5 Torx screwdriver.
  6. Motorola Moto G7 Plus Front Camera Replacement: 6 단계, 이미지 1/2 Motorola Moto G7 Plus Front Camera Replacement: 6 단계, 이미지 2/2
    • Remove the camera housing plate with the opening tool.
  7. Motorola Moto G7 Plus Front Camera Replacement: 7 단계, 이미지 1/1
    • Disconnect the three highlighted connectors as seen in the diagram using the opening tools.
  8. Motorola Moto G7 Plus Front Camera Replacement: 8 단계, 이미지 1/2 Motorola Moto G7 Plus Front Camera Replacement: 8 단계, 이미지 2/2
    • Pry the motherboard away from the frame of the phone using the opening tools.
    • Do not completely remove the motherboard from the device.
    • Remove the camera from the motherboard.
결론
Jackson Anthony All
회원 가입일: 02/15/21
109 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 12
전체 시간: 691
