주요 콘텐츠로 건너뛰기
소개
This guide will show you step-by-step how to replace the back casing.
  1. Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
    • Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
    • Be careful not to poke yourself when handling the push pin because it is very sharp.
  2. Use the T6 screwdriver to remove the four screws holding the casing together.
    • Use the T6 screwdriver to remove the four screws holding the casing together.
    • Note: they are in the same place where you removed the four rubber coverings
  3. Wedge the plastic opening tool in between the top and bottom cases. This may require a little or a lot of force so be careful. Note: the phone should be face up and the plastic opening tool should be face downwards
    • Wedge the plastic opening tool in between the top and bottom cases. This may require a little or a lot of force so be careful.
    • Note: the phone should be face up and the plastic opening tool should be face downwards
    • Once you get the plastic opening tool in, slide it across the side of the phone, making sure to keep the plastic opening tool wedged in between the two casings.
    • Repeat the 3 steps above for the top, bottom, and opposite side.
  4. Gently lift and remove the back casing. Gently lift and remove the back casing.
    • Gently lift and remove the back casing.
결론
Luis Herrera
회원 가입일: 2010년 01월 21일
52 평판
안내서 4개 작성하였습니다
Cal Poly, Team 16-33, Maness Winter 2010 Cal Poly, Team 16-33, Maness Winter 2010 회원
CPSU-MANESS-W10S16G33
4 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 5,013
