소개
This guide will show you step-by-step how to replace the front casing of your phone.
필요한 것
Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
Remove the plastic inner cover by placing the spudger under the left-most side and pry to the left and upwards.
Gently rotate/wiggle the cover until you can pull it off the phone.
Remove the infra red plastic covering,the button on the left side of the phone, and the earphone cover lid by pulling straight up on them with your fingers.
Wedge the plastic opening tool in between the logic board and the small orange band and gently pry upwards.
Simply lift the keyboard buttons with your hands pulling from one side to the other.
Remove the navigation buttons by pushing them with your finger(s) until they come loose.
Now simply peel the buttons off.
다른 한 분이 해당 안내서를 완성하였습니다.
