이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
Use the T6 screwdriver to remove the four screws holding the casing together.
Once you get the plastic opening tool in, slide it across the side of the phone, making sure to keep the plastic opening tool wedged in between the two casings.
Repeat the 3 steps above for the top, bottom, and opposite side.
Remove the plastic inner cover by placing the spudger under the left-most side and pry to the left and upwards.
Gently rotate/wiggle the cover until you can pull it off the phone.
Using your fingers, remove the plastic piece that holds the camera in place.
Carefully pry up the upper circuit board with the spudger.
The second picture shows what your phone should look like when the upper circuit board is removed.
Take out the camera and attached chip with the iPod removal tool. Carefully pry the chip off its connection and the camera will come out too.
Remove the infra red plastic covering,the button on the left side of the phone, and the earphone cover lid by pulling straight up on them with your fingers.
Wedge the plastic opening tool in between the logic board and the small orange band and gently pry upwards.
Wedge the spudger in between the logic board and the front casing and gently lift while pulling away from the orange ribbon.
Wedge the plastic opening tool between the LCD screen and the metal casing holding it in and lift gently.
Simply lift the keyboard buttons with your hands pulling from one side to the other.
Remove the navigation buttons by pushing them with your finger(s) until they come loose.
Now simply peel the buttons off.
다른 한 분이 해당 안내서를 완성하였습니다.
