주요 콘텐츠로 건너뛰기
Motorola Moto Q LCD Display Replacment
필요한 것
  1. Motorola Moto Q LCD Display Replacment, Back Casing: 1 단계, 이미지 1/1
    • Use the Push Pin to remove the rubber screw covers by pushing the needle into the rubber and pulling up.
    • Be careful not to poke yourself when handling the push pin because it is very sharp.
  2. Motorola Moto Q LCD Display Replacment: 2 단계, 이미지 1/1
    • Use the T6 screwdriver to remove the four screws holding the casing together.
    • Note: they are in the same place where you removed the four rubber coverings
  3. Motorola Moto Q LCD Display Replacment: 3 단계, 이미지 1/2 Motorola Moto Q LCD Display Replacment: 3 단계, 이미지 2/2
    • Wedge the plastic opening tool in between the top and bottom cases. This may require a little or a lot of force so be careful.
    • Note: the phone should be face up and the plastic opening tool should be face downwards
    • Once you get the plastic opening tool in, slide it across the side of the phone, making sure to keep the plastic opening tool wedged in between the two casings.
    • Repeat the 3 steps above for the top, bottom, and opposite side.
  4. Motorola Moto Q LCD Display Replacment: 4 단계, 이미지 1/2 Motorola Moto Q LCD Display Replacment: 4 단계, 이미지 2/2
    • Gently lift and remove the back casing.
  5. Motorola Moto Q LCD Display Replacment, Camera: 5 단계, 이미지 1/2 Motorola Moto Q LCD Display Replacment, Camera: 5 단계, 이미지 2/2
    • Remove the plastic inner cover by placing the spudger under the left-most side and pry to the left and upwards.
    • Gently rotate/wiggle the cover until you can pull it off the phone.
  6. Motorola Moto Q LCD Display Replacment: 6 단계, 이미지 1/2 Motorola Moto Q LCD Display Replacment: 6 단계, 이미지 2/2
    • Using your fingers, remove the plastic piece that holds the camera in place.
  7. Motorola Moto Q LCD Display Replacment: 7 단계, 이미지 1/2 Motorola Moto Q LCD Display Replacment: 7 단계, 이미지 2/2
    • Carefully pry up the upper circuit board with the spudger.
    • The second picture shows what your phone should look like when the upper circuit board is removed.
  8. Motorola Moto Q LCD Display Replacment: 8 단계, 이미지 1/2 Motorola Moto Q LCD Display Replacment: 8 단계, 이미지 2/2
    • Take out the camera and attached chip with the iPod removal tool. Carefully pry the chip off its connection and the camera will come out too.
  9. Motorola Moto Q LCD Display Replacment, LCD Display: 9 단계, 이미지 1/2 Motorola Moto Q LCD Display Replacment, LCD Display: 9 단계, 이미지 2/2
    • Remove the infra red plastic covering,the button on the left side of the phone, and the earphone cover lid by pulling straight up on them with your fingers.
    • Wedge the plastic opening tool in between the logic board and the small orange band and gently pry upwards.
    • Note: the orange band is connected to the logic board by a small connector.
  10. Motorola Moto Q LCD Display Replacment: 10 단계, 이미지 1/3 Motorola Moto Q LCD Display Replacment: 10 단계, 이미지 2/3 Motorola Moto Q LCD Display Replacment: 10 단계, 이미지 3/3
    • Wedge the spudger in between the logic board and the front casing and gently lift while pulling away from the orange ribbon.
    • Note: it is easier to remove the logic board by prying upwards near the top of left corner phone.
  11. Motorola Moto Q LCD Display Replacment: 11 단계, 이미지 1/3 Motorola Moto Q LCD Display Replacment: 11 단계, 이미지 2/3 Motorola Moto Q LCD Display Replacment: 11 단계, 이미지 3/3
    • Wedge the plastic opening tool between the LCD screen and the metal casing holding it in and lift gently.
    • Note: the LCD screen is also held in place by a silver tape. Simply pull the screen from one side to other to remove the screen completely.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Luis Herrera
회원 가입일: 01/21/10
52 평판
안내서 4개 작성하였습니다
Cal Poly, Team 16-33, Maness Winter 2010 Cal Poly, Team 16-33, Maness Winter 2010 회원
CPSU-MANESS-W10S16G33
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 2,904
