주요 콘텐츠로 건너뛰기
Motorola Moto X 2nd Generation Back Cover Replacement
필요한 것
동영상 개요
  1. Motorola Moto X 2nd Generation Back Cover Replacement, Back Cover: 1 단계, 이미지 3개 중 1개 Motorola Moto X 2nd Generation Back Cover Replacement, Back Cover: 1 단계, 이미지 3개 중 2개 Motorola Moto X 2nd Generation Back Cover Replacement, Back Cover: 1 단계, 이미지 3개 중 3개
    • Remove SIM card tray.
  2. Motorola Moto X 2nd Generation Back Cover Replacement: 2 단계, 이미지 3개 중 1개 Motorola Moto X 2nd Generation Back Cover Replacement: 2 단계, 이미지 3개 중 2개 Motorola Moto X 2nd Generation Back Cover Replacement: 2 단계, 이미지 3개 중 3개
    • Insert the eject pin into the hole in the SIM card tray port and push the back cover with effort to open a gap.
    • Place the guitar pick into the gap.
  3. Motorola Moto X 2nd Generation Back Cover Replacement: 3 단계, 이미지 2개 중 1개 Motorola Moto X 2nd Generation Back Cover Replacement: 3 단계, 이미지 2개 중 2개
    • Slide the guitar pick to cut the adhesive sticker under the back cover. It's a little strong.
    • At last, peel off the soft back cover.If you get the new back cover without the logo ring, you need to remove the logo ring from old back cover.
결론
다른 19명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Sophia
회원 가입일: 03/25/14
43,905 평판
안내서 62개를 작성함
3가이드 댓글
The guide was easy to follow. I managed to complete it successfully using the recommended tools.
Hassan Almarzooq - 답글
It seems that material and time alters the ease with which it opens. My bamboo cover, which has been my precious back cover, was very hard to remove. Probably temperature has affected the glue, that glued it on even more. I needed a scalpel to give me leverage enough, since the eject pin wasn't strong enough to pry it open.
[deleted] - 답글
What type of adhesive do you use to reseal the back cover?
sfcvickers - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 18
전체 시간: 26,276
