주요 콘텐츠로 건너뛰기
Motorola Moto X 2nd Generation Power and Volume flex cable Replacement
필요한 것
  1. Motorola Moto X 2nd Generation Power and Volume flex cable Replacement, Power and Volume flex cable: 1 단계, 이미지 1/3 Motorola Moto X 2nd Generation Power and Volume flex cable Replacement, Power and Volume flex cable: 1 단계, 이미지 2/3 Motorola Moto X 2nd Generation Power and Volume flex cable Replacement, Power and Volume flex cable: 1 단계, 이미지 3/3
    • Remove SIM card tray.
  2. Motorola Moto X 2nd Generation Power and Volume flex cable Replacement: 2 단계, 이미지 1/3 Motorola Moto X 2nd Generation Power and Volume flex cable Replacement: 2 단계, 이미지 2/3 Motorola Moto X 2nd Generation Power and Volume flex cable Replacement: 2 단계, 이미지 3/3
    • Remove back cover.
  3. Motorola Moto X 2nd Generation Power and Volume flex cable Replacement: 3 단계, 이미지 1/2 Motorola Moto X 2nd Generation Power and Volume flex cable Replacement: 3 단계, 이미지 2/2
    • Remove those two rubber cover.
  4. Motorola Moto X 2nd Generation Power and Volume flex cable Replacement: 4 단계, 이미지 1/2 Motorola Moto X 2nd Generation Power and Volume flex cable Replacement: 4 단계, 이미지 2/2
    • Release power connecting flex connector and battery connector.
  5. Motorola Moto X 2nd Generation Power and Volume flex cable Replacement: 5 단계, 이미지 1/2 Motorola Moto X 2nd Generation Power and Volume flex cable Replacement: 5 단계, 이미지 2/2
    • Twist off all 18 black torx screws and remove the middle housing from front assembly.
  6. Motorola Moto X 2nd Generation Power and Volume flex cable Replacement: 6 단계, 이미지 1/2 Motorola Moto X 2nd Generation Power and Volume flex cable Replacement: 6 단계, 이미지 2/2
    • Release power flex connector from connecting flex.
  7. Motorola Moto X 2nd Generation Power and Volume flex cable Replacement: 7 단계, 이미지 1/3 Motorola Moto X 2nd Generation Power and Volume flex cable Replacement: 7 단계, 이미지 2/3 Motorola Moto X 2nd Generation Power and Volume flex cable Replacement: 7 단계, 이미지 3/3
    • Remove securing bracket and side buttons.
  8. Motorola Moto X 2nd Generation Power and Volume flex cable Replacement: 8 단계, 이미지 1/1
    • Pry up and remove the power flex.
결론
다른 10명이 해당 안내서를 완성하였습니다.
Sophia
회원 가입일: 03/25/14
43,810 평판
안내서 62개 작성하였습니다
댓글 3개
Followed your instructions. Volume works, power button still no go.
It clicks fine, but nothing happens..
Carlo Petermann - 답글
I have the same issue. Any ideas? Resolutions?
sagar bhale -
The screwdriver is T4 on my european moto X 2014, not T3!!
Clément Masci - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 5,092
