이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
If possible, drain the battery before disassembly. When the battery is charged, there's increased risk of a dangerous thermal event if the battery is overheated or damaged during repairs.
If your display is cracked, completely cover it with packing tape to contain the glass shards and avoid injury.
Prepare an iOpener and heat the front of the phone along its left edge for about two minutes, or until it's slightly too hot to touch. This will help soften the adhesive securing the display.
For reference, refer to the first image, showing the back of the display assembly (right) after it has been removed from the phone (left).
If you plan to re-use the display assembly, pay particular attention to the side edges. When slicing through the glue in this area, you must be careful to insert your tool less than 2 mm, or your tool will come in contact with the display panel and damage it.
Playing cards are a safer, but much slower, prying tool. The soft paper cards are less likely to damage the display panel, which is good news if you plan to reuse it.
Apply a suction cup to the display, near the middle of the left edge.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
This may require a significant amount of force, but you only need to open a very slight gap with the suction cup to insert your tool.
If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools very fast, so you may need to heat it repeatedly.
Insert an opening pick (or playing card) into the gap you opened behind the display.
Slide the tool all along the left edge of the phone to slice through the adhesive securing the display.
Heat the front of the phone between the display and the lower edge to soften the adhesive underneath.
Slice through the glue under the lower bezel, being careful not to damage the fingerprint sensor.
Slide or roll your tool past the lower edge of the fingerprint sensor and continue to the other side. Do not pry directly underneath the sensor.
Heat the right edge of the phone to soften the adhesive securing the right edge of the display.
Slide your tool along the right edge of the phone to separate the glue securing the display.
Insert your tool at the top right corner of the phone, and begin to slide it underneath the top bezel to separate the glue.
When your tool just passes the left edge of the earpiece speaker, stop.
Slide or roll your tool over the top of the flash module for the selfie camera to avoid damaging it.
If the display remains stuck, re-heat and slice the adhesive repeatedly as needed.
Lift the display from the left edge and swing it open, away from the phone.
While holding the display open, use the point of a spudger to pry up the locking tab on the fingerprint sensor cable's ZIF connector.
At the opposite end of the phone, use your spudger to flip open the locking tab on the display cable connector.
Gently pull the fingerprint sensor cable to slide it out of its socket, disconnecting it from the motherboard.
Gently pull the display cable to slide it out of its socket on the motherboard.
Remove the SIM card by firmly pressing the 0.8 SIM eject tool into the SIM card removal hole on the top left edge of the phone until the SIM slot pops out of the phone.
Completely remove the SIM card from the device.
Remove the six 3mm T3 screws from the camera cover at the top of the phone.
Pry the camera cover up with your tools to pop the camera cover clips loose.
다른 10명이 해당 안내서를 완성하였습니다.
