소개
Use this guide to remove or replace the screen on your Motorola Moto Z3 Play.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Warning: Because of the strong adhesive securing the display, minimal clearance for inserting your tools, and high heat required, there's a good chance of accidentally damaging the display when removing it. If you're replacing the display anyway, then you don't have to worry—but if you intend to re-use the display, heed all warnings and work very carefully.
필요한 것
If possible, drain the battery before disassembly. When the battery is charged, there's increased risk of a dangerous thermal event if the battery is overheated or damaged during repairs.
If your display is cracked, completely cover it with packing tape to contain the glass shards and avoid injury.
Prepare an iOpener and heat the front of the phone along its right edge for about two minutes, or until it's slightly too hot to touch. This will help soften the adhesive securing the display.
In the following steps, you will separate the display assembly from the Moto Z3 Play's chassis.
If you plan to re-use the display assembly, pay particular attention to the side edges. When slicing through the glue in this area, you must be careful to insert your tool less than ~1.5 mm, or your tool will come in contact with the LCD and damage it.
Take special care when cutting near the display cable. If you pry too deep or too forcefully, it is very easy to damage the cable. If you encounter extra resistance around this area, do not try to force the pick forward. Pull it out and reinsert it on the other side of the display cable before you continue cutting.
Apply a suction cup to the display, near the middle of the right edge.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the display and rear case.
This may require a significant amount of force, but you only need to open a very slight gap with the suction cup to insert your tool.
If you have trouble, apply more heat to further soften the adhesive, and try again. The adhesive cools quickly, so you may need to heat it repeatedly.
Insert an opening pick (or playing card) into the gap you opened behind the display.
If the display remains stuck, re-heat and slice the adhesive repeatedly as needed.
Lift the display from the right edge and swing it open, away from the phone. The display is still attached to the phone chassis at the lower left edge, so do not fully remove it yet.
Use the point of a spudger to pry up the locking tab on the display cable's ZIF connector.
다른 10명이 해당 안내서를 완성하였습니다.
댓글 한 개
Por que las partes que venden no llegan a México me interesaría su kit de reparación para este articulo
