주요 콘텐츠로 건너뛰기
Motorola Nextel i880 Key Pad Replacement
필요한 것
  1. Motorola Nextel i880 Key Pad Replacement, Key Pad: 1 단계, 이미지 1/1
    • Remove the back cover by sliding the clip and lifting up the bottom of the cover.
  2. Motorola Nextel i880 Key Pad Replacement: 2 단계, 이미지 1/2 Motorola Nextel i880 Key Pad Replacement: 2 단계, 이미지 2/2
    • Remove screws 1 through 4.
  3. Motorola Nextel i880 Key Pad Replacement: 3 단계, 이미지 1/1
    • Once all four screws are removed, you should be able to pop off the back half of the phone.
  4. Motorola Nextel i880 Key Pad Replacement: 4 단계, 이미지 1/1
    • Flip the logic board up to reveal the back of the keypad.
  5. Motorola Nextel i880 Key Pad Replacement: 5 단계, 이미지 1/1
    • Peal the back of the keypad off of the phone. (Highlighted area are the parts where you can begin to peal from). That white pad is what is being replaced.
  6. Motorola Nextel i880 Key Pad Replacement: 6 단계, 이미지 1/1
    • Take your new key pad and line the holes up with the pegs sticking out of the phone. (Pegs are highlighted).
    • Secure the rest of the key pad.
  7. Motorola Nextel i880 Key Pad Replacement: 7 단계, 이미지 1/1
    • Put the logic board back into place and reattach cable number 1.
  8. Motorola Nextel i880 Key Pad Replacement: 8 단계, 이미지 1/1
    • Snap the front and back of the phone back together and reinsert screws 1 through 4.
결론
Danielle Matthews
회원 가입일: 10/17/14
127 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 6-7, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-7, Vijaybhaskar Fall 2014 회원
UMASSD-VIJAYBHASKAR-F14S6G7
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 5
전체 시간: 131
