주요 콘텐츠로 건너뛰기
Motorola Nextel i880 Logic Board Replacement
필요한 것
  1. Motorola Nextel i880 Logic Board Replacement, Logic Board: 1 단계, 이미지 1/1
    • Remove back cover of the phone by disengaging the clip and lifting up on the cover.
  2. Motorola Nextel i880 Logic Board Replacement: 2 단계, 이미지 1/2 Motorola Nextel i880 Logic Board Replacement: 2 단계, 이미지 2/2
    • Remove screws 1 through 4.
  3. Motorola Nextel i880 Logic Board Replacement: 3 단계, 이미지 1/1
    • Once all four screws are removed, you should be able to take off the back half of the phone.
  4. Motorola Nextel i880 Logic Board Replacement: 4 단계, 이미지 1/1
    • Remove the connection at the top right of the circuit board.
  5. Motorola Nextel i880 Logic Board Replacement: 5 단계, 이미지 1/1
    • Insert new logic board and reattach top right cable.
  6. Motorola Nextel i880 Logic Board Replacement: 6 단계, 이미지 1/1
    • Snap the front and back of the phone back together and reinsert screws 1 through 4.
결론
Danielle Matthews
회원 가입일: 10/17/14
127 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 6-7, Vijaybhaskar Fall 2014 UMass Dartmouth, Team 6-7, Vijaybhaskar Fall 2014 회원
UMASSD-VIJAYBHASKAR-F14S6G7
3 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 222
