주요 콘텐츠로 건너뛰기
Motorola Photon 4G MB855 Battery Replacement
필요한 것
  1. Motorola Photon 4G MB855 Battery Replacement, Removing the Back Cover: 1 단계, 이미지 1/2 Motorola Photon 4G MB855 Battery Replacement, Removing the Back Cover: 1 단계, 이미지 2/2
    • Insert a plastic opening tool into the indentation at the bottom of the phone between the front and rear covers.
    • Lift the back cover from the bottom and remove it from the phone.
  2. Motorola Photon 4G MB855 Battery Replacement, Removing the Battery: 2 단계, 이미지 1/2 Motorola Photon 4G MB855 Battery Replacement, Removing the Battery: 2 단계, 이미지 2/2
    • Insert a plastic opening tool, or your finger, into the notch in between the sim card and the battery and lift the battery upward.
    • Remove the battery from your phone.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Jennifer Osterman
회원 가입일: 10/07/14
153 평판
안내서 1개 작성함
USF Tampa, Team 8-6, Leahy Fall 2014 USF Tampa, Team 8-6, Leahy Fall 2014 회원
USFT-LEAHY-F14S8G6
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 1,359
