주요 콘텐츠로 건너뛰기
Motorola Photon 4G MB855 Midframe Replacement
필요한 것
  1. Motorola Photon 4G MB855 Midframe Replacement, Removing the Back Cover: 1 단계, 이미지 1/2 Motorola Photon 4G MB855 Midframe Replacement, Removing the Back Cover: 1 단계, 이미지 2/2
    • Insert a plastic opening tool into the indentation at the bottom of the phone between the front and rear covers.
    • Lift the back cover from the bottom and remove it from the phone.
  2. Motorola Photon 4G MB855 Midframe Replacement, Removing the Battery: 2 단계, 이미지 1/2 Motorola Photon 4G MB855 Midframe Replacement, Removing the Battery: 2 단계, 이미지 2/2
    • Insert a plastic opening tool, or your finger, into the notch in between the sim card and the battery and lift the battery upward.
    • Remove the battery from your phone.
  3. Motorola Photon 4G MB855 Midframe Replacement, Removing Screw Covers: 3 단계, 이미지 1/3 Motorola Photon 4G MB855 Midframe Replacement, Removing Screw Covers: 3 단계, 이미지 2/3 Motorola Photon 4G MB855 Midframe Replacement, Removing Screw Covers: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Remove all five screw covers with tweezers located in the picture.
  4. Motorola Photon 4G MB855 Midframe Replacement, Removing the Midframe: 4 단계, 이미지 1/3 Motorola Photon 4G MB855 Midframe Replacement, Removing the Midframe: 4 단계, 이미지 2/3 Motorola Photon 4G MB855 Midframe Replacement, Removing the Midframe: 4 단계, 이미지 3/3
    • Remove the 10 T4 Torx screws securing the midframe to the display assembly.
    • Gently pry the midframe from the display assembly and remove it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Eddie Krause
회원 가입일: 10/07/14
260 평판
안내서 3개 작성하였습니다
USF Tampa, Team 8-6, Leahy Fall 2014 USF Tampa, Team 8-6, Leahy Fall 2014 회원
USFT-LEAHY-F14S8G6
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 332
