주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola Q Global Camera Replacement
필요한 것
  1. Motorola Q Global Camera Replacement, Battery: 1 단계, 이미지 2개 중 1개 Motorola Q Global Camera Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Turn the phone face down.
    • Press and hold the release button in the middle of the back panel.
    • Slide the bottom panel down to remove.
  2. Motorola Q Global Camera Replacement: 2 단계, 이미지 2개 중 1개 Motorola Q Global Camera Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the battery pack by prying it out with a fingernail, screw driver or other opening tool at the tab shown.
    • When reinserting the battery, make sure the contacts in the battery are lined up with the contacts in the phone.
  3. Motorola Q Global Camera Replacement, Camera: 3 단계, 이미지 1개 중 1개
    • Press inward on the upper casing.
  4. Motorola Q Global Camera Replacement: 4 단계, 이미지 1개 중 1개
    • Slide the upper case to the right and lift up.
    • Lift the camera sticker so that it doesn't get damaged.
  5. Motorola Q Global Camera Replacement: 5 단계, 이미지 2개 중 1개 Motorola Q Global Camera Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the six labeled screws with a T5 Torx Screwdriver.
  6. Motorola Q Global Camera Replacement: 6 단계, 이미지 1개 중 1개
    • Once the screws are removed, use the plastic opening tool to remove the black casing.
  7. Motorola Q Global Camera Replacement: 7 단계, 이미지 2개 중 1개 Motorola Q Global Camera Replacement: 7 단계, 이미지 2개 중 2개
    • Remove both screws on the mounted surface with a T5 screwdriver.
  8. Motorola Q Global Camera Replacement: 8 단계, 이미지 2개 중 1개 Motorola Q Global Camera Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the glued, mounted surface by lifting it from underneath the SIM card slot by using the plastic opening tool.
  9. Motorola Q Global Camera Replacement: 9 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to lift the camera from the phone.
  10. Motorola Q Global Camera Replacement: 10 단계, 이미지 1개 중 1개
    • The new camera can now be attached to the motherboard.
결론
작성자
7다른 기여자 명과 함께
Jorge Vanegas Moran
회원 가입일: 10/03/12
8 평판
안내서 1개를 작성함
Cal Poly, Team 6-31, Regan Fall 2012 Cal Poly, Team 6-31, Regan Fall 2012 회원
CPSU-REGAN-F12S6G31
5 회원들
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 20
지난 30일: 49
전체 시간: 870
