이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Turn the phone face down.
Press and hold the release button in the middle of the back panel.
Slide the bottom panel down to remove.
Remove the battery pack by prying it out with a fingernail, screw driver or other opening tool at the tab shown.
Slide the upper case to the right and lift up.
Lift the camera sticker so that it doesn't get damaged.
Once the screws are removed, use the plastic opening tool to remove the black casing.
Remove the glued, mounted surface by lifting it from underneath the SIM card slot by using the plastic opening tool.
