주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola Q Global Display screen Replacement
필요한 것
  1. Motorola Q Global Display screen Replacement, Battery: 1 단계, 이미지 2개 중 1개 Motorola Q Global Display screen Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Turn the phone face down.
    • Press and hold the release button in the middle of the back panel.
    • Slide the bottom panel down to remove.
  2. Motorola Q Global Display screen Replacement: 2 단계, 이미지 2개 중 1개 Motorola Q Global Display screen Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the battery pack by prying it out with a fingernail, screw driver or other opening tool at the tab shown.
    • When reinserting the battery, make sure the contacts in the battery are lined up with the contacts in the phone.
  3. Motorola Q Global Display screen Replacement, Display screen: 3 단계, 이미지 1개 중 1개
    • Press inwardly on the upper casing to release.
  4. Motorola Q Global Display screen Replacement: 4 단계, 이미지 1개 중 1개
    • Slide the upper case rightward and lift up.
    • Lift the camera sticker so that it does not get damaged.
  5. Motorola Q Global Display screen Replacement: 5 단계, 이미지 2개 중 1개 Motorola Q Global Display screen Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the 6 screws using the T5 torx screwdriver.
  6. Motorola Q Global Display screen Replacement: 6 단계, 이미지 1개 중 1개
    • Once the screws are removed, use the plastic opening tool to remove the black casing.
  7. Motorola Q Global Display screen Replacement: 7 단계, 이미지 2개 중 1개 Motorola Q Global Display screen Replacement: 7 단계, 이미지 2개 중 2개
    • Remove both screws on the mounted surface with a T5 screwdriver.
  8. Motorola Q Global Display screen Replacement: 8 단계, 이미지 2개 중 1개 Motorola Q Global Display screen Replacement: 8 단계, 이미지 2개 중 2개
    • Remove the glued, mounted surface by lifting it from underneath the SIM card slot by using the plastic opening tool.
  9. Motorola Q Global Display screen Replacement: 9 단계, 이미지 2개 중 1개 Motorola Q Global Display screen Replacement: 9 단계, 이미지 2개 중 2개
    • Lift the motherboard about 90 degrees and remove the circuit with the orange ribbon (from the keyboard) by gently lifting the circuit.
  10. Motorola Q Global Display screen Replacement: 10 단계, 이미지 2개 중 1개 Motorola Q Global Display screen Replacement: 10 단계, 이미지 2개 중 2개
    • Separate the front plate from the circuit board.
    • The LCD screen is attached to the circuit board by a thin ribbon.
    • Switch the lock on top of the circuit entry from horizontal to vertical.
  11. Motorola Q Global Display screen Replacement: 11 단계, 이미지 1개 중 1개
    • Insert the new LCD screen into the circuit.
결론
작성자
8다른 기여자 명과 함께
Will Dickman
회원 가입일: 09/27/12
28 평판
안내서 3개를 작성함
Cal Poly, Team 6-31, Regan Fall 2012 Cal Poly, Team 6-31, Regan Fall 2012 회원
CPSU-REGAN-F12S6G31
5 회원들
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 20
지난 30일: 73
전체 시간: 1,077
