소개
This guide outlines the steps to disassemble the Q Global to access the internal speakers. It can be used to replace or repair a damaged speaker.
부품
부품은 필요하지 않습니다.
  1. Turn the phone face down.
    • Turn the phone face down.
    • Press and hold the release button in the middle of the back panel.
    • Slide the bottom panel down to remove.
  2. Remove the battery pack by prying it out with a fingernail, screw driver or other opening tool at the tab shown. When reinserting the battery, make sure the contacts in the battery are lined up with the contacts in the phone.
    • Remove the battery pack by prying it out with a fingernail, screw driver or other opening tool at the tab shown.
    • When reinserting the battery, make sure the contacts in the battery are lined up with the contacts in the phone.
  3. Press inwardly on the upper casing until it pops out of the phone.
    • Press inwardly on the upper casing until it pops out of the phone.
  4. US$100.00 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  5. Slide the upper case rightward and lift up.
    • Slide the upper case rightward and lift up.
    • Lift the camera sticker so that it does not get damaged.
  6. Remove the six labeled screws with a T5 torx screw driver. Remove the six labeled screws with a T5 torx screw driver.
    • Remove the six labeled screws with a T5 torx screw driver.
  7. Once the screws are removed, use the plastic opening tool to remove the black casing.
    • Once the screws are removed, use the plastic opening tool to remove the black casing.
  8. Remove the speakers by using the plastic remover tool.
    • Remove the speakers by using the plastic remover tool.
  9. Insert the new speakers by gently pressing them down into place.
    • Insert the new speakers by gently pressing them down into place.
결론
Carlos De La Parra
회원 가입일: 2012년 10월 05일
14 평판
안내서 1개 작성함
Cal Poly, Team 6-31, Regan Fall 2012 Cal Poly, Team 6-31, Regan Fall 2012 회원
CPSU-REGAN-F12S6G31
5 회원들
안내서 5개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 540
