주요 콘텐츠로 건너뛰기
Motorola Q700 Sidekick Speaker and Camera Replacement
필요한 것
  1. Motorola Q700 Sidekick Speaker and Camera Replacement, Phone: 1 단계, 이미지 1/1
    • When looking at the front of the phone, use the Plastic Opening Tool to pry off the four buttons located in each of the corners on the front.
  2. Motorola Q700 Sidekick Speaker and Camera Replacement: 2 단계, 이미지 1/1
    • Turn the phone face-down. Remove the back cover, exposing the battery.
    • Use the Plastic Opening Tool to pry the battery out of the phone.
  3. Motorola Q700 Sidekick Speaker and Camera Replacement: 3 단계, 이미지 1/1
    • Using the appropriate size Phillips screwdriver, unscrew the four screws located in each of the corners on the back of the device.
    • Although the battery is shown in this picture, please remember to make sure that it is removed in order to proceed with disassembly.
  4. Motorola Q700 Sidekick Speaker and Camera Replacement: 4 단계, 이미지 1/1
    • After removal of the back screws, use the Plastic Opening Tool to carefully separate the top and bottom halves of the device.
  5. Motorola Q700 Sidekick Speaker and Camera Replacement: 5 단계, 이미지 1/1
    • Using the appropriate size Phillips screwdriver, remove any screws that are attached or associated with the keypad and carefully remove keypad from the device.
  6. Motorola Q700 Sidekick Speaker and Camera Replacement: 6 단계, 이미지 1/1
    • On the back of the device, you will see individual green and yellow technical pieces. Remove those two pieces from the phone with your fingers and set aside.
  7. Motorola Q700 Sidekick Speaker and Camera Replacement: 7 단계, 이미지 1/1
    • You should now have all of the pieces separated and disassembled for your device.
  8. Motorola Q700 Sidekick Speaker and Camera Replacement, Speaker and Camera: 8 단계, 이미지 1/1
    • complete dissassembly as instructed by guide
  9. Motorola Q700 Sidekick Speaker and Camera Replacement: 9 단계, 이미지 1/1
    • Remove camera piece from casing
  10. Motorola Q700 Sidekick Speaker and Camera Replacement: 10 단계, 이미지 1/1
    • replace with new camera piece into casing and reassemble by reversing dissemble procedure
결론
Rich
회원 가입일: 04/08/13
125 평판
안내서 6개 작성하였습니다
SUNY Cortland, Team 1-4, Getto Spring 2013 SUNY Cortland, Team 1-4, Getto Spring 2013 회원
SUNYCORT-GETTO-S13S1G4
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 10
전체 시간: 230
