주요 콘텐츠로 건너뛰기
Motorola RAZR Maxx HD External Speaker Replacement
필요한 것
  1. Motorola RAZR Maxx HD External Speaker Replacement, Screen Removal: 1 단계, 이미지 1/2 Motorola RAZR Maxx HD External Speaker Replacement, Screen Removal: 1 단계, 이미지 2/2
    • Use the Torx T5 Screwdriver to remove two 5.0 mm screws at the bottom of the phone.
  2. Motorola RAZR Maxx HD External Speaker Replacement: 2 단계, 이미지 1/2 Motorola RAZR Maxx HD External Speaker Replacement: 2 단계, 이미지 2/2
    • To remove the SIM card, use an unfolded paperclip to press down on the metal plate on the left side of the phone until it pops up.
  3. Motorola RAZR Maxx HD External Speaker Replacement: 3 단계, 이미지 1/2 Motorola RAZR Maxx HD External Speaker Replacement: 3 단계, 이미지 2/2
    • Gently push the screen toward the top edge of the phone and tilt the screen to reveal the black flex cables.
    • Do NOT remove the screen all the way or the flex cables will be damaged.
  4. Motorola RAZR Maxx HD External Speaker Replacement: 4 단계, 이미지 1/2 Motorola RAZR Maxx HD External Speaker Replacement: 4 단계, 이미지 2/2
    • Release the two black ribbon flex cables by gently pulling up on the connection using the spudger. Then lift the screen to remove.
    • Make sure to remove the flex cables before completely removing the screen.
    • When reassembling, align the white bands on the edge of the screen so that a connection is made.
  5. Motorola RAZR Maxx HD External Speaker Replacement, Circuit Board: 5 단계, 이미지 1/3 Motorola RAZR Maxx HD External Speaker Replacement, Circuit Board: 5 단계, 이미지 2/3 Motorola RAZR Maxx HD External Speaker Replacement, Circuit Board: 5 단계, 이미지 3/3
    • Remove the plastic yellow tape on the battery connector using the spudger.
    • Pry up on the orange connection to release it from the motherboard.
  6. Motorola RAZR Maxx HD External Speaker Replacement: 6 단계, 이미지 1/1
    • Unscrew all ten 4.0 mm screws on the motherboard using a T5 Torx screwdriver.
  7. Motorola RAZR Maxx HD External Speaker Replacement: 7 단계, 이미지 1/2 Motorola RAZR Maxx HD External Speaker Replacement: 7 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using tweezers, remove the clear plastic covering on the speaker.
    • Pry open the connection by lifting up on the speaker wire connector.
  8. Motorola RAZR Maxx HD External Speaker Replacement: 8 단계, 이미지 1/2 Motorola RAZR Maxx HD External Speaker Replacement: 8 단계, 이미지 2/2
    • Using tweezers, remove the back facing camera cover.
  9. Motorola RAZR Maxx HD External Speaker Replacement: 9 단계, 이미지 1/2 Motorola RAZR Maxx HD External Speaker Replacement: 9 단계, 이미지 2/2
    • Using the spudger tool, release the yellow ribbon cable on the headphone jack cover by pushing up on the connection.
    • Remove the cover from the motherboard.
  10. Motorola RAZR Maxx HD External Speaker Replacement: 10 단계, 이미지 1/1
    • Release the yellow flex cable on the right side of the phone using the spudger by lifting up on the retaining clip.
  11. Motorola RAZR Maxx HD External Speaker Replacement: 11 단계, 이미지 1/3 Motorola RAZR Maxx HD External Speaker Replacement: 11 단계, 이미지 2/3 Motorola RAZR Maxx HD External Speaker Replacement: 11 단계, 이미지 3/3
    • Wedge the spudger between the motherboard and the back case.
    • Work your way around the entire edge of the motherboard to release it and remove it from the back of the phone.
  12. Motorola RAZR Maxx HD External Speaker Replacement, External Speaker: 12 단계, 이미지 1/2 Motorola RAZR Maxx HD External Speaker Replacement, External Speaker: 12 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use tweezers to remove the speaker from the top left of the phone by pulling upward.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Anna Sullivan
회원 가입일: 02/01/15
880 평판
안내서 3개 작성하였습니다
Cal Poly, Team 8-40, Amido Winter 2015 Cal Poly, Team 8-40, Amido Winter 2015 회원
CPSU-AMIDO-W15S8G40
5 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 465
