주요 콘텐츠로 건너뛰기
Motorola RAZR Maxx HD Front-Facing Camera Replacement
필요한 것
  1. Motorola RAZR Maxx HD Front-Facing Camera Replacement, Screen Removal: 1 단계, 이미지 1/2 Motorola RAZR Maxx HD Front-Facing Camera Replacement, Screen Removal: 1 단계, 이미지 2/2
    • Use the Torx T5 Screwdriver to remove two 5.0 mm screws at the bottom of the phone.
  2. Motorola RAZR Maxx HD Front-Facing Camera Replacement: 2 단계, 이미지 1/2 Motorola RAZR Maxx HD Front-Facing Camera Replacement: 2 단계, 이미지 2/2
    • To remove the SIM card, use an unfolded paperclip to press down on the metal plate on the left side of the phone until it pops up.
  3. Motorola RAZR Maxx HD Front-Facing Camera Replacement: 3 단계, 이미지 1/2 Motorola RAZR Maxx HD Front-Facing Camera Replacement: 3 단계, 이미지 2/2
    • Gently push the screen toward the top edge of the phone and tilt the screen to reveal the black flex cables.
    • Do NOT remove the screen all the way or the flex cables will be damaged.
  4. Motorola RAZR Maxx HD Front-Facing Camera Replacement: 4 단계, 이미지 1/2 Motorola RAZR Maxx HD Front-Facing Camera Replacement: 4 단계, 이미지 2/2
    • Release the two black ribbon flex cables by gently pulling up on the connection using the spudger. Then lift the screen to remove.
    • Make sure to remove the flex cables before completely removing the screen.
    • When reassembling, align the white bands on the edge of the screen so that a connection is made.
  5. Motorola RAZR Maxx HD Front-Facing Camera Replacement, Front-Facing Camera: 5 단계, 이미지 1/1
    • On the back of the LCD display, release the yellow front-facing camera ribbon cable by gently lifting upward on the black retaining clip with the spudger.
  6. Motorola RAZR Maxx HD Front-Facing Camera Replacement: 6 단계, 이미지 1/3 Motorola RAZR Maxx HD Front-Facing Camera Replacement: 6 단계, 이미지 2/3 Motorola RAZR Maxx HD Front-Facing Camera Replacement: 6 단계, 이미지 3/3
    • With a Torx T3 screwdriver, unscrew the two 2.0 mm screws on front-facing camera mounting bracket. Then lift to remove it.
  7. Motorola RAZR Maxx HD Front-Facing Camera Replacement: 7 단계, 이미지 1/2 Motorola RAZR Maxx HD Front-Facing Camera Replacement: 7 단계, 이미지 2/2
    • Use tweezers to remove the front-facing camera by lifting it from the LCD display frame.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jacob Syage
회원 가입일: 02/01/15
284 평판
안내서 2개 작성하였습니다
Cal Poly, Team 8-40, Amido Winter 2015 Cal Poly, Team 8-40, Amido Winter 2015 회원
CPSU-AMIDO-W15S8G40
5 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 286
