주요 콘텐츠로 건너뛰기
Motorola RAZR Maxx HD Rear-Facing Camera Replacement
필요한 것
  1. Motorola RAZR Maxx HD Rear-Facing Camera Replacement, Screen Removal: 1 단계, 이미지 1/2 Motorola RAZR Maxx HD Rear-Facing Camera Replacement, Screen Removal: 1 단계, 이미지 2/2
    • Use the Torx T5 Screwdriver to remove two 5.0 mm screws at the bottom of the phone.
  2. Motorola RAZR Maxx HD Rear-Facing Camera Replacement: 2 단계, 이미지 1/2 Motorola RAZR Maxx HD Rear-Facing Camera Replacement: 2 단계, 이미지 2/2
    • To remove the SIM card, use an unfolded paperclip to press down on the metal plate on the left side of the phone until it pops up.
  3. Motorola RAZR Maxx HD Rear-Facing Camera Replacement: 3 단계, 이미지 1/2 Motorola RAZR Maxx HD Rear-Facing Camera Replacement: 3 단계, 이미지 2/2
    • Gently push the screen toward the top edge of the phone and tilt the screen to reveal the black flex cables.
    • Do NOT remove the screen all the way or the flex cables will be damaged.
  4. Motorola RAZR Maxx HD Rear-Facing Camera Replacement: 4 단계, 이미지 1/2 Motorola RAZR Maxx HD Rear-Facing Camera Replacement: 4 단계, 이미지 2/2
    • Release the two black ribbon flex cables by gently pulling up on the connection using the spudger. Then lift the screen to remove.
    • Make sure to remove the flex cables before completely removing the screen.
    • When reassembling, align the white bands on the edge of the screen so that a connection is made.
  5. Motorola RAZR Maxx HD Rear-Facing Camera Replacement, Rear-Facing Camera: 5 단계, 이미지 1/2 Motorola RAZR Maxx HD Rear-Facing Camera Replacement, Rear-Facing Camera: 5 단계, 이미지 2/2
    • Using a T5 Torx screwdriver, unscrew the two 4.0mm screws on the rear-facing camera cover.
  6. Motorola RAZR Maxx HD Rear-Facing Camera Replacement: 6 단계, 이미지 1/2 Motorola RAZR Maxx HD Rear-Facing Camera Replacement: 6 단계, 이미지 2/2
    • Use tweezers to remove the rear-facing camera cover.
  7. Motorola RAZR Maxx HD Rear-Facing Camera Replacement: 7 단계, 이미지 1/2 Motorola RAZR Maxx HD Rear-Facing Camera Replacement: 7 단계, 이미지 2/2
    • Use the spudger to gently lift the rear-facing camera until it is detached from the back cover.
    • Release the yellow ribbon cable by lifting up on the connection to the motherboard with the spudger.
  8. Motorola RAZR Maxx HD Rear-Facing Camera Replacement: 8 단계, 이미지 1/2 Motorola RAZR Maxx HD Rear-Facing Camera Replacement: 8 단계, 이미지 2/2
    • Use tweezers to gently remove the rear-facing camera by lifting it up off of the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Hristo
회원 가입일: 02/01/15
150 평판
안내서 1개 작성함
Cal Poly, Team 8-40, Amido Winter 2015 Cal Poly, Team 8-40, Amido Winter 2015 회원
CPSU-AMIDO-W15S8G40
5 회원들
안내서 18개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 382
