주요 콘텐츠로 건너뛰기
Motorola RAZR V3i Battery Replacement
필요한 것
  1. Motorola RAZR V3i Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Make sure the phone is turned off by holding down the red End Call/Power button until the phone shuts off.
    • If you have a phone case, it has to be removed.
  2. Motorola RAZR V3i Battery Replacement: 2 단계, 이미지 1/3 Motorola RAZR V3i Battery Replacement: 2 단계, 이미지 2/3 Motorola RAZR V3i Battery Replacement: 2 단계, 이미지 3/3
    • Close the phone and find the battery cover button, located on the backside of the phone underneath the hinge.
    • Using your finger, press down on the button to release the back cover. Then, lift the cover and remove it from the phone completely.
    • The flat edge of a credit card or other flat object will also work.
  3. Motorola RAZR V3i Battery Replacement: 3 단계, 이미지 1/3 Motorola RAZR V3i Battery Replacement: 3 단계, 이미지 2/3 Motorola RAZR V3i Battery Replacement: 3 단계, 이미지 3/3
    • Remove the battery by pushing down on it from the top while gently pulling it outwards.
    • Be careful not to use too much force as the battery retaining tab could be damaged.
결승점
다른 5명이 해당 안내서를 완성하였습니다.
Nigel
회원 가입일: 09/06/11
133 평판
안내서 2개 작성하였습니다
Cuesta, Team 1-5, Zipperian Fall 2011 Cuesta, Team 1-5, Zipperian Fall 2011 회원
CUESTA-ZIPPERIAN-F11S1G5
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 10
30일 전: 53
전체 시간: 7,184
