주요 콘텐츠로 건너뛰기
Motorola RIZR Z3 Motherboard Replacement
필요한 것
  1. Motorola RIZR Z3 Motherboard Replacement, Battery: 1 단계, 이미지 1/2 Motorola RIZR Z3 Motherboard Replacement, Battery: 1 단계, 이미지 2/2
    • Press the panel release button on the top of the phone and simultaneously pull the rear panel away from the phone.
  2. Motorola RIZR Z3 Motherboard Replacement: 2 단계, 이미지 1/2 Motorola RIZR Z3 Motherboard Replacement: 2 단계, 이미지 2/2
    • Tilt the battery by lifting at the exposed notch.
    • Slide the battery out of its casing.
  3. Motorola RIZR Z3 Motherboard Replacement, Motherboard: 3 단계, 이미지 1/1
    • Use a T4 screwdriver to unscrew all six of the .216 inch screws that attach the housing to the case.
  4. Motorola RIZR Z3 Motherboard Replacement: 4 단계, 이미지 1/2 Motorola RIZR Z3 Motherboard Replacement: 4 단계, 이미지 2/2
    • Use a plastic opening tool to lift the plastic casing.
    • Pull the plastic casing directly away from the phone.
  5. Motorola RIZR Z3 Motherboard Replacement: 5 단계, 이미지 1/1
    • Lift the black rubber loudspeaker housing up and out of the plastic casing.
  6. Motorola RIZR Z3 Motherboard Replacement: 6 단계, 이미지 1/2 Motorola RIZR Z3 Motherboard Replacement: 6 단계, 이미지 2/2
    • Use a plastic opening tool to gently lift up the SIM card reader, located above the rubber antenna casing. You should hear a click as it releases.
    • Caution: Remove carefully, if broken, the phone will not be able to make calls.
  7. Motorola RIZR Z3 Motherboard Replacement: 7 단계, 이미지 1/2 Motorola RIZR Z3 Motherboard Replacement: 7 단계, 이미지 2/2
    • Use a plastic opening tool to pry the two ribbon cable connectors, unclipping them from their sockets on the motherboard.
    • Caution: Remove carefully, if broken, the phone will not function properly.
  8. Motorola RIZR Z3 Motherboard Replacement: 8 단계, 이미지 1/2 Motorola RIZR Z3 Motherboard Replacement: 8 단계, 이미지 2/2
    • Use a plastic opening tool to gently pry the motherboard up until you can tilt it with your fingers. Unhook it from the casing and slowly pull it out.
    • Caution: Do this gently Unclipping too fast may cause damage to your phone.
결론
Andrew Brock
회원 가입일: 10/07/11
8 평판
안내서 1개 작성함
Cal Poly, Team 5-34, Amido Fall 2011 Cal Poly, Team 5-34, Amido Fall 2011 회원
CPSU-AMIDO-F11S5G34
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 1,321
