주요 콘텐츠로 건너뛰기
Motorola RIZR Z3 Screen Replacement
필요한 것
  1. Motorola RIZR Z3 Screen Replacement, Battery: 1 단계, 이미지 2개 중 1개 Motorola RIZR Z3 Screen Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Press the panel release button on the top of the phone and simultaneously pull the rear panel away from the phone.
  2. Motorola RIZR Z3 Screen Replacement: 2 단계, 이미지 2개 중 1개 Motorola RIZR Z3 Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Tilt the battery by lifting at the exposed notch.
    • Slide the battery out of its casing.
  3. Motorola RIZR Z3 Screen Replacement, Motherboard: 3 단계, 이미지 1개 중 1개
    • Use a T4 screwdriver to unscrew all six of the .216 inch screws that attach the housing to the case.
  4. Motorola RIZR Z3 Screen Replacement: 4 단계, 이미지 2개 중 1개 Motorola RIZR Z3 Screen Replacement: 4 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to lift the plastic casing.
    • Pull the plastic casing directly away from the phone.
  5. Motorola RIZR Z3 Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Lift the black rubber loudspeaker housing up and out of the plastic casing.
  6. Motorola RIZR Z3 Screen Replacement: 6 단계, 이미지 2개 중 1개 Motorola RIZR Z3 Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to gently lift up the SIM card reader, located above the rubber antenna casing. You should hear a click as it releases.
    • Caution: Remove carefully, if broken, the phone will not be able to make calls.
  7. Motorola RIZR Z3 Screen Replacement: 7 단계, 이미지 2개 중 1개 Motorola RIZR Z3 Screen Replacement: 7 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to pry the two ribbon cable connectors, unclipping them from their sockets on the motherboard.
    • Caution: Remove carefully, if broken, the phone will not function properly.
  8. Motorola RIZR Z3 Screen Replacement: 8 단계, 이미지 2개 중 1개 Motorola RIZR Z3 Screen Replacement: 8 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to gently pry the motherboard up until you can tilt it with your fingers. Unhook it from the casing and slowly pull it out.
    • Caution: Do this gently Unclipping too fast may cause damage to your phone.
  9. Motorola RIZR Z3 Screen Replacement, Screen: 9 단계, 이미지 1개 중 1개
    • Turn the phone to the front.
    • Push the keypad out through the plastic casing.
  10. Motorola RIZR Z3 Screen Replacement: 10 단계, 이미지 1개 중 1개
    • Turn the phone to the side.
    • Thread the hinges of the slider through their holes in the casing and pull the slider down and away from the casing.
  11. Motorola RIZR Z3 Screen Replacement: 11 단계, 이미지 1개 중 1개
    • Use a T4 screwdriver to unscrew the two .15 inch screws holding the LCD to the faceplate.
  12. Motorola RIZR Z3 Screen Replacement: 12 단계, 이미지 3개 중 1개 Motorola RIZR Z3 Screen Replacement: 12 단계, 이미지 3개 중 2개 Motorola RIZR Z3 Screen Replacement: 12 단계, 이미지 3개 중 3개
    • Use a spudger to pry the plastic screen casing partially up from the LCD unit.
    • Use the spudger to pry the ribbon cable away from its clip on the LCD unit.
    • Caution: If the LCD will not function properly if this ribbon cable is broken.
    • Pull the plastic screen casing directly away from the LCD unit.
  13. Motorola RIZR Z3 Screen Replacement: 13 단계, 이미지 1개 중 1개
    • Turn the plastic screen casing over.
    • Carefully use a spudger to push the on the two clips holding the navigational pad in place.
    • You may have to pry the pad away from the plastic screen casing with the spudger.
  14. Motorola RIZR Z3 Screen Replacement: 14 단계, 이미지 2개 중 1개 Motorola RIZR Z3 Screen Replacement: 14 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to pry the screen up, being mindful of the glue holding the screen to its casing.
    • Pull the screen directly away from the casing.
결론
작성자
5다른 기여자 명과 함께
Brooke Shuford
회원 가입일: 10/10/11
65 평판
안내서 3개를 작성함
Cal Poly, Team 5-34, Amido Fall 2011 Cal Poly, Team 5-34, Amido Fall 2011 회원
CPSU-AMIDO-F11S5G34
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 5
전체 시간: 1,479
