주요 콘텐츠로 건너뛰기
필요한 것
동영상 개요
해당 분해도는 수리 안내서가 아닙니다. Motorola razr 수리는 저희 서비스 설명서를 사용하십시오.
  1. Motorola Razr Teardown, Motorola Razr Teardown: 1 단계, 이미지 1/3 Motorola Razr Teardown, Motorola Razr Teardown: 1 단계, 이미지 2/3 Motorola Razr Teardown, Motorola Razr Teardown: 1 단계, 이미지 3/3
    • It has been said that we only care about repairability and tend to overlook important specs like color accuracy, but this is only partially true. There are many other specs we can overlook, such as:
    • 6.2" foldable plastic OLED display with 2142 × 876 resolution (~373 PPI)
    • 2.2 GHz octa-core Qualcomm Snapdragon 710 processor paired with 6 GB of RAM
    • 128 GB of internal storage
    • 2510 mAh of battery power
    • One 16 MP, ƒ/1.7 main camera with dual-pixel autofocus and one 5 MP, ƒ/2.0 selfie camera
    • No official IP rating, but Motorola claims that it is "Splash-proof with [a] water resistant nanocoating"
    • One thing that probably won't be returning from the original Razr is a user-removable battery. Those were some good times!
  2. Motorola Razr Teardown: 2 단계, 이미지 1/3 Motorola Razr Teardown: 2 단계, 이미지 2/3 Motorola Razr Teardown: 2 단계, 이미지 3/3
    • Before putting our Razr under the knife (or dull plastic edge), we take an X-ray peek with some help from our friends at Creative Electron.
    • Rolling your mouse over the two X-rays, you'll note that a few passive components move up and down slightly as the phone opens and shuts. Those are probably attached to that flexible OLED display, which actually slides down and tucks into the chin of the phone as it closes.
    • Meanwhile, it appears the brains of this operation lie in the bottom half of the phone—while the top half houses the extra screen, a battery, and the camera setup.
    • And if you look really closely, you can see the inner workings of the continuous geared hinge at the center of all the folding action. More on that later.
  3. Motorola Razr Teardown: 3 단계, 이미지 1/3 Motorola Razr Teardown: 3 단계, 이미지 2/3 Motorola Razr Teardown: 3 단계, 이미지 3/3
    • Back in our day, the Motorola Razr was the coolest thing around. We're happy to see that the new Razr keeps the sleek look of the original—despite the significant upgrades to the screen, camera, speakers, and silicon it packs.
    • All that modern-day gear adds bulk, though! The new Razr is 35% wider and 118% heavier than our 2004 V3, making it less pocketable than you might think.
    • Pockets aside, a closer look at the folding action reveals a small gap between the hinge and display on each side. Similar gaps, you might say, to those that contributed to the demise of some of the first Galaxy Folds.
    • This gap appears mainly midway through the folding action, and doesn't plague the Razr in open configuration. So maybe it's safe? But at $1500 USD, it's a potentially expensive "maybe."
  4. Motorola Razr Teardown: 4 단계, 이미지 1/3 Motorola Razr Teardown: 4 단계, 이미지 2/3 Motorola Razr Teardown: 4 단계, 이미지 3/3
    • Our first target is the Razr's lower rear cover. Behind the fancy folding façade, this is still a smartphone like any other, so we're guessing a hot iOpener is our ticket in.
    • Just a little heat does the trick! We're able to wedge an opening pick in there and begin our journey.
    • We're grateful for the innovations of modern smartphones, but boy, would we love to see the slide-off plastic or metal access panels of yesteryear.
    • Once all the glue is sliced, the cover can wiggle free. But wait! Eagle-eyed viewers may spot the fingerprint sensor cable next to the home button, just waiting to be torn by an eager disassembler.
    • Without repair documentation, booby traps like these can turn a simple fix into a DIY nightmare.
  5. Motorola Razr Teardown: 5 단계, 이미지 1/3 Motorola Razr Teardown: 5 단계, 이미지 2/3 Motorola Razr Teardown: 5 단계, 이미지 3/3
    • Battery Ho! But no other fun goodies below this cover, so we opt to pop the Quick View display off the other side. Despite some nasty glue, it eventually comes free.
    • Outer display out of the way, we catch our first glimpse at the second battery. The first battery's ready for removal in the bottom half of the phone, but the second is still hiding behind some cables in the top half.
    • Above the batteries, the single 16 MP main camera stares back at us. These days it's pretty rare to see just one main/rear camera on a smartphone, but it's easy to understand that Motorola had other things on their mind in the four years they spent developing this phone.
    • Wanna steal this look? Show off the internals of your phone (without the gluey mess) with our teardown wallpapers!
  6. Motorola Razr Teardown: 6 단계, 이미지 1/3 Motorola Razr Teardown: 6 단계, 이미지 2/3 Motorola Razr Teardown: 6 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Mako Driver Kit - 64 Precision Bits
    $39.95
    구매
    • So far disassembly has been relatively straightforward. As we hone in on the flexible display, we hope we don't screw it up—but for now, we're breezily unscrewing some Torx screws with our handy Mako kit!
    • With a bit of alcoholic coercion, the first battery of two comes free (weighing in at 4.7 Wh and just 2.6 mm thin)—but more on those later, we're on the fast track to silicon town now!
    • One brief pit stop on our race to motherboard glory: in removing the vibration motor (a pretty boring coin-style one) we spot some curious slime!
    • This goop could potentially be some equivalent of dielectric grease (more commonly seen in cars)—an inexpensive way to add a bit of water resistance to the board.
  7. Motorola Razr Teardown: 7 단계, 이미지 1/3 Motorola Razr Teardown: 7 단계, 이미지 2/3 Motorola Razr Teardown: 7 단계, 이미지 3/3
    • Digging out the motherboard we spy some serious shielding strategy—what treasures could these caps cover?
    • Qualcomm SDM710 Snapdragon 710 processor
    • Samsung KM2V7001CM 6 GB LPDDR4 memory and 128 GB storage package
    • Skyworks SKY 78185-11 Low Band 2G/3G/4G Module
    • Skyworks SKY 78187-11 High Band 2G/3G/4G Module
    • SDR660 003 radio frequency IC
    • Qualcomm PM670 & PM670A power management ICs
    • Qualcomm WCN3990 WiFi 802.11ac, Bluetooth LE, and FM SoC
  8. Motorola Razr Teardown: 8 단계, 이미지 1/3 Motorola Razr Teardown: 8 단계, 이미지 2/3 Motorola Razr Teardown: 8 단계, 이미지 3/3
    • Flipping this floppy foldable is a lot easier after a few more screws, and gives us access to the cameras and the second battery.
    • Eager to get our hands on that bendy OLED, we execute a series of complex teardown maneuvers:
    • First, we evacuate another handful of Torx screws. Then we carefully extract a metal bracket. Finally, we tenderly unstick the thick cable that runs through the hinge and over the second battery.
    • Did that sound easy? It wasn't. We're surprised that Motorola is offering to replace these displays for just $299.
  9. Motorola Razr Teardown: 9 단계, 이미지 1/3 Motorola Razr Teardown: 9 단계, 이미지 2/3 Motorola Razr Teardown: 9 단계, 이미지 3/3
    • With the pOLED display removed, we're a bit dismayed that the battery comes with it. Prying against this flexible sheet for a battery swap doesn't seem ideal, even if the battery is in a metal caddy.
    • Nine steps in we finally have both batteries: This yellow rectangle packs slightly more punch, at 1265 mAh and 4.8 Wh, than the wafer-thin 4.7 Wh cell we extracted earlier.
    • The batteries add up to Motorola's claim of 2510 mAh, or 9.7 Wh of power. For comparison, just one of the Galaxy Fold batteries has about the same capacity of both of these things put together. The giant L-shaped iPhone XS Max battery manages to dwarf them all at 3969 mAh, or 15.04 Wh.
    • The pOLED display (allegedly a BOE screen, potentially using LG Display technology) isn't giving up many secrets—but we do spy some Samsung tech:
    • Samsung S6SY77CX, likely an iteration of Samsung's popular touch controller.
    • GigaDevice GD25LQ40C 512 KB serial NOR flash memory
    • pOLED display driver
  10. Motorola Razr Teardown: 10 단계, 이미지 1/3 Motorola Razr Teardown: 10 단계, 이미지 2/3 Motorola Razr Teardown: 10 단계, 이미지 3/3
    • Here's something you don't usually see on a smartphone teardown: mechanical parts. Big ones!
    • The folding action of this Razr comprises a continuous geared hinge, a cat-head cam, two support plates, and a few springs.
    • Motorola's patents illustrate the way the cam and the support plates work together to protect the fragile OLED display. They provide support and hold it taut while the phone is open, then get out of the way to allow for a nice big radius (which helps to prevent a crease in the display from forming) when it shuts.
    • In X-ray closeups of the hinge area, you can see the continuous geared hinge as well as the springs embedded in each side of the frame.
    • The gears keep both halves of the phone moving synchronously, very similar to the gears in the Galaxy Fold.
    • The springs in each half of the phone press inward against the cam in the middle to hold the phone open or closed, and provide some resistance when moving the hinge.
  11. Motorola Razr Teardown: 11 단계, 이미지 1/1
    • Motorola’s nostalgia-stoking Razr officially wins the award for most complicated phone-based contraption we’ve ever taken apart. We’re impressed with the numerous feats of engineering that Moto pulled off to resurrect their iconic clamshell.
    • It won’t win any awards for serviceability, but just bringing this impossible gizmo into existence was such a tall order that we’re not surprised serviceability didn’t make it into v1.0. It’s fun to see how they made it happen (if not so fun to tease it all apart).
    • We're going to score it all the same (just like we did the Galaxy Fold), but we know this is a first-gen design and we shouldn't expect functionality and repairability to come all at once.
    • We doubt the foldable craze will end anytime soon—Samsung's recently announced Galaxy Z Flip is already on its way. Hopefully manufacturers will figure out how to make these things both durable and repairable before too long, especially at these price points...
    • Thanks for sticking around! Here's some bonus material: A 360-degree X-ray view inside the Moto Razr.
    • This would have been so much easier than a physical teardown—X-rays make everything look easy. But hey at least a teardown delivers full color!
    • PS: Are you getting Spinning Dancer vibes, too? Is it spinning left? Right? You decide—we've got to score this thing.
  12. 최종 결론
    • The only driver you'll need is a standard T3 Torx.
    • The delicate primary display is replaceable, if you're determined.
    • Every repair starts (and ends) with stubborn, glued-on outer covers.
    • Replacing the battery—or rather, batteries—requires near-total disassembly.
    • The charging port is soldered directly to the main board.
    • Complex construction and multiple flex cable booby traps makes for tricky repair work.
    수리 용이성 점수
    수리 용이성 10점 중 1점
    (10은 가장 쉬운 수리를 뜻합니다)
Taylor Dixon
회원 가입일: 06/26/18
67,033 평판
안내서 94개 작성하였습니다
댓글 7개
Nice teardown! Wonder if this “folding phone” thing will stick around for long…
Maxwell Yun - 답글
Man, convincing my brain to get the image to spin backwards hurts. I was able to see the phone spinning backwards (while actually looking at it directly) when the phone was facing away. If I was only just barely looking at it from the corner of my eye, I could get the entire thing spinning in reverse.
Let’s just say that the brain interprets the reverse spinning very oddly, so the phone looks like it is warping around the edges while it is spinning.
Zacharry Williams - 답글
Imagine folding it to close it but you accidentally fold it the wrong way.
Ethan Zuo - 답글
If you somehow manage to fold it backwards, I applaud you, because you just wasted yourself $1500.
TheYootz Media Group -
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 60
30일 전: 288
전체 시간: 59,613
