주요 콘텐츠로 건너뛰기
Motorola Razr V3 Antenna Replacement
필요한 것
  1. Motorola Razr V3 Antenna Replacement, Battery: 1 단계, 이미지 1/2 Motorola Razr V3 Antenna Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the back cover by pressing down the silver button.
    • Pull the cover away from the phone.
  2. Motorola Razr V3 Antenna Replacement: 2 단계, 이미지 1/2 Motorola Razr V3 Antenna Replacement: 2 단계, 이미지 2/2
    • Remove the battery by pushing down on the top and pulling it away from the phone.
  3. Motorola Razr V3 Antenna Replacement, Antenna: 3 단계, 이미지 1/1
    • Unscrew the two 5mm T6 Torx screws form the phone.
  4. Motorola Razr V3 Antenna Replacement: 4 단계, 이미지 1/1
    • Pry open the back of the phone using the spudger. There are four clips, one on the left, one on the right, and two on the bottom of the phone.
    • You can rotate the phone left and right to get easier access while prying.
    • Make sure to fold back of phone down (or left depending on your orientation) after separating from body as there is ribbon connecting the back to the phone's body which can be ripped if pulled the wrong way.
    • The tab as well as the plastic clips are fragile, be careful when using them.
  5. Motorola Razr V3 Antenna Replacement: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Using tweezers, disconnect the copper ribbon on the left side of the phone by pulling it up from the circuit board.
    • The clear part below the circuit board is the antenna.
  6. Motorola Razr V3 Antenna Replacement: 6 단계, 이미지 1/1
    • Remove the antenna by pushing in the tabs on the sides with the spudger, and pulling it out.
    • These clips are also fragile.
    • When reassembling, make sure the copper piece of the antenna is properly inserted between the two copper clips that stick up from the phone.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ross Byers
회원 가입일: 04/18/13
243 평판
안내서 2개 작성하였습니다
Cal Poly, Team 3-46, Amido Spring 2013 Cal Poly, Team 3-46, Amido Spring 2013 회원
CPSU-AMIDO-S13S3G46
4 회원들
안내서 8개 작성하였습니다
댓글 한 개
Elok tenan Jan sing posting
Haryanto - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 18
전체 시간: 3,752
