주요 콘텐츠로 건너뛰기
Motorola Razr V3 LCD Screens and Call Speaker Replacement
필요한 것
  1. Motorola Razr V3 LCD Screens and Call Speaker Replacement, Battery: 1 단계, 이미지 2개 중 1개 Motorola Razr V3 LCD Screens and Call Speaker Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Remove the back cover by pressing down the silver button.
    • Pull the cover away from the phone.
  2. Motorola Razr V3 LCD Screens and Call Speaker Replacement: 2 단계, 이미지 2개 중 1개 Motorola Razr V3 LCD Screens and Call Speaker Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the battery by pushing down on the top and pulling it away from the phone.
  3. Motorola Razr V3 LCD Screens and Call Speaker Replacement, Upper Casing: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use tweezers to pry off the four rubber screw covers from the inside face.
    • Our phone is missing the two left screw covers, be careful not to lose yours too!
  4. Motorola Razr V3 LCD Screens and Call Speaker Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the four T5 Torx screws that were underneath the rubber covers.
  5. Motorola Razr V3 LCD Screens and Call Speaker Replacement: 5 단계, 이미지 1개 중 1개
    • Use the plastic opening tool to pry the top cover away from the phone.
    • The side buttons on the phone may fall out when the top cover is separated from the phone. They can easily be put back by placing them in their original spot.
  6. Motorola Razr V3 LCD Screens and Call Speaker Replacement, LCD Screens and Call Speaker: 6 단계, 이미지 1개 중 1개
    • Use the spudger to pry off the plastic lens that covers the LCD screen.
    • You will feel some resistance due to the adhesive put in between the screen and the plastic lens. Be careful not to damage the LCD screen.
    • When reassembling, put the screen lens on last. It is much easier to align the lens when you use the upper casing as a guide.
  7. Motorola Razr V3 LCD Screens and Call Speaker Replacement: 7 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use the tweezers to gently pry the silver ribbon cable up towards you.
    • Be careful not to damage the ribbon cable when pulling it off, as it can be fragile.
  8. Motorola Razr V3 LCD Screens and Call Speaker Replacement: 8 단계, 이미지 2개 중 1개 Motorola Razr V3 LCD Screens and Call Speaker Replacement: 8 단계, 이미지 2개 중 2개
    • Use he tweezers to flip up the tab.
    • With the tab up, gently pull the copper ribbon cable out.
    • Be careful not to damage the ribbon cable when pulling it out, as it is fragile.
  9. Motorola Razr V3 LCD Screens and Call Speaker Replacement: 9 단계, 이미지 2개 중 1개 Motorola Razr V3 LCD Screens and Call Speaker Replacement: 9 단계, 이미지 2개 중 2개
    • Use the tweezers to gently fold the buttons away from the phone.
    • Be careful not to rip buttons off of the board. You will feel some resistance from the adhesive, but they should easily fold up if they are pulled from the bottom.
    • Use the spudger the speaker from the phone.
  10. Motorola Razr V3 LCD Screens and Call Speaker Replacement: 10 단계, 이미지 2개 중 1개 Motorola Razr V3 LCD Screens and Call Speaker Replacement: 10 단계, 이미지 2개 중 2개
    • Place your thumb on the screen and gently push into the phone.
    • It should come out pretty easy. If it is not budging go back and check over the steps again.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Christian
회원 가입일: 04/18/13
257 평판
안내서 2개를 작성함
Cal Poly, Team 3-46, Amido Spring 2013 Cal Poly, Team 3-46, Amido Spring 2013 회원
CPSU-AMIDO-S13S3G46
4 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 19
지난 30일: 62
전체 시간: 10,702
