주요 콘텐츠로 건너뛰기
Motorola Razr V3 SIM Card Replacement
  1. Motorola Razr V3 SIM Card Replacement, Battery: 1 단계, 이미지 1/2 Motorola Razr V3 SIM Card Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the back cover by pressing down the silver button.
    • Pull the cover away from the phone.
  2. Motorola Razr V3 SIM Card Replacement: 2 단계, 이미지 1/2 Motorola Razr V3 SIM Card Replacement: 2 단계, 이미지 2/2
    • Remove the battery by pushing down on the top and pulling it away from the phone.
  3. Motorola Razr V3 SIM Card Replacement, SIM Card: 3 단계, 이미지 1/1
    • Remove the SIM card by pulling it toward the top of the phone with your thumb.
결론
다른 10명이 해당 안내서를 완성하였습니다.
Ross Byers
회원 가입일: 04/18/13
243 평판
안내서 2개 작성하였습니다
Cal Poly, Team 3-46, Amido Spring 2013 Cal Poly, Team 3-46, Amido Spring 2013 회원
CPSU-AMIDO-S13S3G46
4 회원들
안내서 8개 작성하였습니다
댓글 5개
What size SIM card does the razr v3 use?
Hoy Kim - 답글
Do you remove the sim from its casing before placing in phone
redeemed78 -
Where can I BUY a Sim Card For the Motorola V3 Razr GSM Flip Cellphone
Thomas Rawlins - 답글
Where can I Buy a Sim Card for a Motorola Razr GSM v3 Cellphone?
Thomas Rawlins - 답글
Boost Mobile On sale .99 cents on Bring your own Phone Plan!!!
sixx19cat69 -
댓글 쓰기
조회 통계:
24 시간 전: 12
7일 전: 44
30일 전: 167
전체 시간: 35,379
