주요 콘텐츠로 건너뛰기
Motorola Razr V3c Keypad Cover (CDMA) Replacement
필요한 것
  1. Motorola Razr V3c Keypad Cover (CDMA) Replacement, Battery (CDMA): 1 단계, 이미지 1/3 Motorola Razr V3c Keypad Cover (CDMA) Replacement, Battery (CDMA): 1 단계, 이미지 2/3 Motorola Razr V3c Keypad Cover (CDMA) Replacement, Battery (CDMA): 1 단계, 이미지 3/3
    • Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
    • Lift and remove the rear panel away from the V3c.
  2. Motorola Razr V3c Keypad Cover (CDMA) Replacement: 2 단계, 이미지 1/2 Motorola Razr V3c Keypad Cover (CDMA) Replacement: 2 단계, 이미지 2/2
    • Remove the battery by pushing in the top of the battery and lifting it away from the phone.
  3. Motorola Razr V3c Keypad Cover (CDMA) Replacement, Keypad Cover (CDMA): 3 단계, 이미지 1/1
    • Remove the two T6 screws on the back of the phone.
  4. Motorola Razr V3c Keypad Cover (CDMA) Replacement: 4 단계, 이미지 1/1
    • Use the plastic opening tool to pop the bottom part of the back case out.
    • The back case is connected to the phone with a ribbon cable; take care not to pull too hard or violently on the cable.
  5. Motorola Razr V3c Keypad Cover (CDMA) Replacement: 5 단계, 이미지 1/1
    • Gently pull back case out and lay it over to the side.
    • Now pull up on the cable attaching the back case to the phone body to separate the two parts. Lay the back case aside for now.
  6. Motorola Razr V3c Keypad Cover (CDMA) Replacement: 6 단계, 이미지 1/1
    • Remove the two T6 screws securing the plastic speaker cover to the phone.
  7. Motorola Razr V3c Keypad Cover (CDMA) Replacement: 7 단계, 이미지 1/1
    • Pull off the lower front casing.
    • The metal shield will come off when the lower front casing is removed. Make sure to replace this when reassembling the lower bottom casing.
  8. Motorola Razr V3c Keypad Cover (CDMA) Replacement: 8 단계, 이미지 1/1
    • Pull the silver plastic cover down away from the rest of the phone.
  9. Motorola Razr V3c Keypad Cover (CDMA) Replacement: 9 단계, 이미지 1/1
    • Push the metal tabs along the perimeter of the device through towards the keyboard with your fingers.
  10. Motorola Razr V3c Keypad Cover (CDMA) Replacement: 10 단계, 이미지 1/1
    • Gently lift up on the keypad with the plastic opening tool while being careful not to bend the thin metal portion lining the keypad.
결론
다른 2명이 해당 안내서를 완성하였습니다.
krisko
회원 가입일: 01/14/10
104 평판
안내서 4개 작성하였습니다
Cal Poly, Team 11-4, Forte Winter 2010 Cal Poly, Team 11-4, Forte Winter 2010 회원
CPSU-FORTE-W10S11G4
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 7,062
