이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
Lift and remove the rear panel away from the V3c.
Remove the battery by pushing in the top of the battery and lifting it away from the phone.
Use the plastic opening tool to pop the bottom and the sides off the back casing.
Peel off the connector between the motherboard and the body of the phone.
Pull out the white plastic cover by unclipping the two plastic pieces shown.
Pull out the motherboard.
You may also now replace the bottom lower casing
Unscrew the two screws holding the plastic speaker cover to the phone with a T5 screwdriver
다른 한 분이 해당 안내서를 완성하였습니다.
