주요 콘텐츠로 건너뛰기
Motorola Razr V3c Motherboard (CDMA) Replacement
필요한 것
  1. Motorola Razr V3c Motherboard (CDMA) Replacement, Battery (CDMA): 1 단계, 이미지 1/3 Motorola Razr V3c Motherboard (CDMA) Replacement, Battery (CDMA): 1 단계, 이미지 2/3 Motorola Razr V3c Motherboard (CDMA) Replacement, Battery (CDMA): 1 단계, 이미지 3/3
    • Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
    • Lift and remove the rear panel away from the V3c.
  2. Motorola Razr V3c Motherboard (CDMA) Replacement: 2 단계, 이미지 1/2 Motorola Razr V3c Motherboard (CDMA) Replacement: 2 단계, 이미지 2/2
    • Remove the battery by pushing in the top of the battery and lifting it away from the phone.
  3. Motorola Razr V3c Motherboard (CDMA) Replacement, Speaker (CDMA): 3 단계, 이미지 1/1
    • Unscrew the two screws in the back using the T6.
  4. Motorola Razr V3c Motherboard (CDMA) Replacement: 4 단계, 이미지 1/1
    • Use the plastic opening tool to pop the bottom and the sides off the back casing.
    • Be careful not to pull the back lower cover off too far as it is connected to the phone body by a ribbon.
  5. Motorola Razr V3c Motherboard (CDMA) Replacement: 5 단계, 이미지 1/1
    • Peel off the connector between the motherboard and the body of the phone.
  6. Motorola Razr V3c Motherboard (CDMA) Replacement: 6 단계, 이미지 1/2 Motorola Razr V3c Motherboard (CDMA) Replacement: 6 단계, 이미지 2/2
    • Pull out the two black rubber covers using tweezers.
    • The second rubber cover is much harder to get out.
  7. Motorola Razr V3c Motherboard (CDMA) Replacement: 7 단계, 이미지 1/2 Motorola Razr V3c Motherboard (CDMA) Replacement: 7 단계, 이미지 2/2
    • Pull out the white plastic cover by unclipping the two plastic pieces shown.
  8. Motorola Razr V3c Motherboard (CDMA) Replacement: 8 단계, 이미지 1/1
    • Pull out the speaker.
  9. Motorola Razr V3c Motherboard (CDMA) Replacement, Motherboard (CDMA): 9 단계, 이미지 1/2 Motorola Razr V3c Motherboard (CDMA) Replacement, Motherboard (CDMA): 9 단계, 이미지 2/2
    • Pull out the motherboard.
    • You may also now replace the bottom lower casing
결론
다른 6명이 해당 안내서를 완성하였습니다.
Joshua Ruehlig
회원 가입일: 01/14/10
506 평판
안내서 4개 작성하였습니다
Cal Poly, Team 11-4, Forte Winter 2010 Cal Poly, Team 11-4, Forte Winter 2010 회원
CPSU-FORTE-W10S11G4
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 3
전체 시간: 6,692
