소개
This guide will show you how to remove the motherboard on a Motorola V3c.
필요한 것
Press down on the the rear panel release button while simultaneously prying the rear panel straight away from the V3c.
Lift and remove the rear panel away from the V3c.
Pull out the motherboard.
You may also now replace the bottom lower casing
거의 끝나갑니다!
결론
다른 6명이 해당 안내서를 완성하였습니다.
