주요 콘텐츠로 건너뛰기
Motorola Razr V3c Screen (CDMA) Replacement
필요한 것
  1. Motorola Razr V3c Screen (CDMA) Replacement, Upper Casing (CDMA): 1 단계, 이미지 1/1
    • Remove the four rubber pieces from all corners of the area around the screen.
  2. Motorola Razr V3c Screen (CDMA) Replacement: 2 단계, 이미지 1/1
    • Use a T4 screwdriver to carefully unscrew all four screws on the outer screen.
    • Be sure that you do not strip or damage the screws.
  3. Motorola Razr V3c Screen (CDMA) Replacement: 3 단계, 이미지 1/1
    • Carefully pry the screen away from the phone using a plastic spudger.
    • Pry slowly, as too much bending will crack the screen. There are also two fragile ribbon cables that connect the screen and camera to the phone.
  4. Motorola Razr V3c Screen (CDMA) Replacement: 4 단계, 이미지 1/3 Motorola Razr V3c Screen (CDMA) Replacement: 4 단계, 이미지 2/3 Motorola Razr V3c Screen (CDMA) Replacement: 4 단계, 이미지 3/3
    • Take the screen housing off of the casing.
    • Watch for small pieces falling out of the screen during this step. Keep track of these pieces.
  5. Motorola Razr V3c Screen (CDMA) Replacement, Camera (CDMA): 5 단계, 이미지 1/2 Motorola Razr V3c Screen (CDMA) Replacement, Camera (CDMA): 5 단계, 이미지 2/2
    • Pry screen cover off with plastic opening tool.
    • The screen cover has some adhesive holding it to the screen.
  6. Motorola Razr V3c Screen (CDMA) Replacement: 6 단계, 이미지 1/1
    • Remove small black sticker covering the camera ribbon connector.
  7. Motorola Razr V3c Screen (CDMA) Replacement: 7 단계, 이미지 1/1
    • Flip over small hinge that covers the camera ribbon connection.
  8. Motorola Razr V3c Screen (CDMA) Replacement: 8 단계, 이미지 1/3 Motorola Razr V3c Screen (CDMA) Replacement: 8 단계, 이미지 2/3 Motorola Razr V3c Screen (CDMA) Replacement: 8 단계, 이미지 3/3
    • Pull off the rubber camera cover and camera.
    • The camera and camera cover may come off either separately or together.
  9. Motorola Razr V3c Screen (CDMA) Replacement, Screen (CDMA): 9 단계, 이미지 1/1
    • Disconnect the metallic ribbon cover.
  10. Motorola Razr V3c Screen (CDMA) Replacement: 10 단계, 이미지 1/2 Motorola Razr V3c Screen (CDMA) Replacement: 10 단계, 이미지 2/2
    • Remove and replace the screen.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Joshua Ruehlig
회원 가입일: 01/14/10
506 평판
안내서 4개 작성하였습니다
Cal Poly, Team 11-4, Forte Winter 2010 Cal Poly, Team 11-4, Forte Winter 2010 회원
CPSU-FORTE-W10S11G4
3 회원들
안내서 8개 작성하였습니다
댓글 한 개
Is it a T5 or a T4 for removing the screws?
Francis Reyes - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 9,389
