소개
This guide will help you replace the upper casing on your device. Following these steps will also enable you to replace the camera.
부품
부품은 필요하지 않습니다.
  1. Remove the four rubber pieces from all corners of the area around the screen.
    • Remove the four rubber pieces from all corners of the area around the screen.
  2. Use a T4 screwdriver to carefully unscrew all four screws on the outer screen.
    • Use a T4 screwdriver to carefully unscrew all four screws on the outer screen.
    • Be sure that you do not strip or damage the screws.
  3. US$100 이상 또는 Pro Tech Toolkit을 포함한 모든 주문의 배송은 무료입니다!
    상점 둘러보기
  4. Carefully pry the screen away from the phone using a plastic spudger.
    • Carefully pry the screen away from the phone using a plastic spudger.
    • Pry slowly, as too much bending will crack the screen. There are also two fragile ribbon cables that connect the screen and camera to the phone.
  5. Take the screen housing off of the casing. Watch for small pieces falling out of the screen during this step. Keep track of these pieces. Watch for small pieces falling out of the screen during this step. Keep track of these pieces.
    • Take the screen housing off of the casing.
    • Watch for small pieces falling out of the screen during this step. Keep track of these pieces.
결론
다른 4명이 해당 안내서를 완성하였습니다.
krisko
회원 가입일: 2010년 01월 14일
95 평판
안내서 4개 작성하였습니다
Cal Poly, Team 11-4, Forte Winter 2010 Cal Poly, Team 11-4, Forte Winter 2010 회원
CPSU-FORTE-W10S11G4
3 회원들
안내서 8개 작성하였습니다
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 7
전체 시간: 5,017
