주요 콘텐츠로 건너뛰기
Motorola Razr V3m Keypad Cover Replacement
필요한 것
  1. Motorola Razr V3m Keypad Cover Replacement, Battery: 1 단계, 이미지 1/2 Motorola Razr V3m Keypad Cover Replacement, Battery: 1 단계, 이미지 2/2
    • Press the release button located on the upper edge of the battery cover. At the same time, lift the battery cover away from the phone.
  2. Motorola Razr V3m Keypad Cover Replacement: 2 단계, 이미지 1/2 Motorola Razr V3m Keypad Cover Replacement: 2 단계, 이미지 2/2
    • Push the top edge of the battery and lift away from the phone.
  3. Motorola Razr V3m Keypad Cover Replacement, SIM Card: 3 단계, 이미지 1/2 Motorola Razr V3m Keypad Cover Replacement, SIM Card: 3 단계, 이미지 2/2
    • Gently pull the SIM Card toward the top of the phone with your finger.
  4. Motorola Razr V3m Keypad Cover Replacement, Keypad Cover: 4 단계, 이미지 1/2 Motorola Razr V3m Keypad Cover Replacement, Keypad Cover: 4 단계, 이미지 2/2
    • Remove the two screws from the back panel with a T6 screwdriver.
  5. Motorola Razr V3m Keypad Cover Replacement: 5 단계, 이미지 1/1
    • Carefully use a metal spudger to pry back panel open.
    • The back panel is attached to the phone with a copper ribbon that acts as a hinge.
    • Carefully open out the back panel to the side of the phone corresponding with the hinge.
    • Do not pull back away from phone. It may damage the copper ribbon.
  6. Motorola Razr V3m Keypad Cover Replacement: 6 단계, 이미지 1/2 Motorola Razr V3m Keypad Cover Replacement: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use tweezers to disconnect the copper ribbon from the inside of the back panel.
  7. Motorola Razr V3m Keypad Cover Replacement: 7 단계, 이미지 1/2 Motorola Razr V3m Keypad Cover Replacement: 7 단계, 이미지 2/2
    • Use a T6 Torx bit screwdriver to remove the two screws holding the cover down.
    • The metal shield will come off with the screws; don't forget to reattach it before replacing the screws.
  8. Motorola Razr V3m Keypad Cover Replacement: 8 단계, 이미지 1/2 Motorola Razr V3m Keypad Cover Replacement: 8 단계, 이미지 2/2
    • Remove the keypad cover, located below the keypad on the front of the phone.
  9. Motorola Razr V3m Keypad Cover Replacement: 9 단계, 이미지 1/2 Motorola Razr V3m Keypad Cover Replacement: 9 단계, 이미지 2/2
    • Remove the sticker on the back of the phone.
  10. Motorola Razr V3m Keypad Cover Replacement: 10 단계, 이미지 1/3 Motorola Razr V3m Keypad Cover Replacement: 10 단계, 이미지 2/3 Motorola Razr V3m Keypad Cover Replacement: 10 단계, 이미지 3/3
    • Using a plastic opening tool, push the four metal tabs along the edge of the phone in towards the keypad.
  11. Motorola Razr V3m Keypad Cover Replacement: 11 단계, 이미지 1/3 Motorola Razr V3m Keypad Cover Replacement: 11 단계, 이미지 2/3 Motorola Razr V3m Keypad Cover Replacement: 11 단계, 이미지 3/3
    • Using the plastic opening tool, pry the edges of the keypad until it is loose. Then, pull it off.
    • It is easiest to work your way from left to right when loosening the case.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jonathan Gendron
회원 가입일: 10/28/15
122 평판
안내서 1개 작성함
UMass Dartmouth, Team 3-2, Shastany Fall 2015 UMass Dartmouth, Team 3-2, Shastany Fall 2015 회원
UMASSD-SHASTANY-F15S3G2
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 11
30일 전: 25
전체 시간: 1,071
