주요 콘텐츠로 건너뛰기
Motorola Razr V3m Screen/Camera Replacement
필요한 것
  1. Motorola Razr V3m Screen/Camera Replacement, Battery: 1 단계, 이미지 1/2 Motorola Razr V3m Screen/Camera Replacement, Battery: 1 단계, 이미지 2/2
    • Press the release button located on the upper edge of the battery cover. At the same time, lift the battery cover away from the phone.
  2. Motorola Razr V3m Screen/Camera Replacement: 2 단계, 이미지 1/2 Motorola Razr V3m Screen/Camera Replacement: 2 단계, 이미지 2/2
    • Push the top edge of the battery and lift away from the phone.
  3. Motorola Razr V3m Screen/Camera Replacement, Screen/Camera: 3 단계, 이미지 1/2 Motorola Razr V3m Screen/Camera Replacement, Screen/Camera: 3 단계, 이미지 2/2
    • Remove the 4 screws on the corners of the inside screen with the T4 screwdriver
    • The phone may have rubber plugs covering the screws of the inside screen. If so, remove the rubber plugs with a thin metal needle.
  4. Motorola Razr V3m Screen/Camera Replacement: 4 단계, 이미지 1/1
    • Use a plastic opening tool to pry the external shell off of the phone.
    • Use care when doing this step because you don’t want the external shell or the pieces inside the phone to break.
  5. Motorola Razr V3m Screen/Camera Replacement: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Remove the two side buttons with tweezers.
  6. Motorola Razr V3m Screen/Camera Replacement: 6 단계, 이미지 1/1
    • Use tweezers to remove the circular magnetic ring covering the camera.
  7. Motorola Razr V3m Screen/Camera Replacement: 7 단계, 이미지 1/2 Motorola Razr V3m Screen/Camera Replacement: 7 단계, 이미지 2/2
    • Use a spudger to pry the screen from the inside front part of the phone.
    • You may choose to use tweezers to remove the screen instead.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Daniel Simcock
회원 가입일: 10/24/15
731 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team 3-2, Shastany Fall 2015 UMass Dartmouth, Team 3-2, Shastany Fall 2015 회원
UMASSD-SHASTANY-F15S3G2
4 회원들
안내서 7개 작성하였습니다
댓글 한 개
where can this part be purchased?
Alex Alexander - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 416
