주요 콘텐츠로 건너뛰기
Motorola Razr V3m Speaker Replacement
필요한 것
  1. Motorola Razr V3m Speaker Replacement, Battery: 1 단계, 이미지 1/2 Motorola Razr V3m Speaker Replacement, Battery: 1 단계, 이미지 2/2
    • Press the release button located on the upper edge of the battery cover. At the same time, lift the battery cover away from the phone.
  2. Motorola Razr V3m Speaker Replacement: 2 단계, 이미지 1/2 Motorola Razr V3m Speaker Replacement: 2 단계, 이미지 2/2
    • Push the top edge of the battery and lift away from the phone.
  3. Motorola Razr V3m Speaker Replacement, SIM Card: 3 단계, 이미지 1/2 Motorola Razr V3m Speaker Replacement, SIM Card: 3 단계, 이미지 2/2
    • Gently pull the SIM Card toward the top of the phone with your finger.
  4. Motorola Razr V3m Speaker Replacement, Antenna: 4 단계, 이미지 1/2 Motorola Razr V3m Speaker Replacement, Antenna: 4 단계, 이미지 2/2
    • Remove the two screws from the back panel with a T6 screwdriver.
  5. Motorola Razr V3m Speaker Replacement: 5 단계, 이미지 1/1
    • Carefully use a plastic opening tool to pry back panel open.
    • The back panel is attached to the phone with a copper ribbon that acts as a hinge.
    • Carefully open out the back panel to the side of the phone corresponding with the hinge.
    • Do not pull back away from phone. It may damage the copper ribbon.
  6. Motorola Razr V3m Speaker Replacement: 6 단계, 이미지 1/2 Motorola Razr V3m Speaker Replacement: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use tweezers to disconnect the copper ribbon from the inside of the back panel.
  7. Motorola Razr V3m Speaker Replacement: 7 단계, 이미지 1/1
    • Use tweezers to remove the tiny red and blue rubber covers located on the top of the antenna.
  8. Motorola Razr V3m Speaker Replacement: 8 단계, 이미지 1/2 Motorola Razr V3m Speaker Replacement: 8 단계, 이미지 2/2
    • Use a plastic opening tool to pry the edge of the antenna away from back panel.
    • The antenna may be fastened with two grey clips on either side. If this is so, unfasten two plastic clips located on the edge of the antenna.
    • Lift antenna away from back panel.
  9. Motorola Razr V3m Speaker Replacement, Speaker: 9 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • The Speaker is the round piece located beneath the antenna.
    • Use tweezers to remove the speaker.
결론
Daniel Simcock
회원 가입일: 10/24/15
731 평판
안내서 6개 작성하였습니다
UMass Dartmouth, Team 3-2, Shastany Fall 2015 UMass Dartmouth, Team 3-2, Shastany Fall 2015 회원
UMASSD-SHASTANY-F15S3G2
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 6
전체 시간: 248
