주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
The Motorola SLVR L7 is a compact phone that does not have an excess amount of components to it. However, since the phone is so small and thin, these components are held together with very small screws, tabs, etc. The methods used to disassemble the phone are ones that are able to be done with slightly more common tools than specialized ones.
  1. Remove the phone back cover by pushing down on the black tab located at the top center of the Motorola Phone.
    • Remove the phone back cover by pushing down on the black tab located at the top center of the Motorola Phone.
  2. Remove the battery by pulling the battery from the top center.
    • Remove the battery by pulling the battery from the top center.
결론
Jorge Trujillo
회원 가입일: 2011년 05월 19일
520 평판
안내서 4개 작성하였습니다
CSU Los Angeles, Team 1-1, Nelson Spring 2011 CSU Los Angeles, Team 1-1, Nelson Spring 2011 회원
CSULA-NELSON-S11S1G1
2 회원들
안내서 4개 작성하였습니다
Why are any tools listed as required??? You press the tab on top, tilt it open, pull out the battery.
jason - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 11
전체 시간: 3,239
