주요 콘텐츠로 건너뛰기
Motorola Slvr L7 Camera Assembly Replacement
필요한 것
  1. Motorola Slvr L7 Camera Assembly Replacement, Camera Assembly: 1 단계, 이미지 1/1
    • To ensure safety, discharge your phone battery below 25% before starting. A fully charged lithium-ion battery may cause a fire and/or explosion due to defects or damage.
    • Turn off your phone before beginning disassembly.
    • To replace the camera, first begin by removing the battery.
    • Push down on the black tab at the Motorola phone’s top center to detach the back phone cover and access the battery.
  2. Motorola Slvr L7 Camera Assembly Replacement: 2 단계, 이미지 1/1
    • Remove the battery on the back of the Motorola phone by pulling it away from the back of the phone.
  3. Motorola Slvr L7 Camera Assembly Replacement: 3 단계, 이미지 1/1
    • Remove the four (4) T6 Torx screws from the back of the metal back plate.
  4. Motorola Slvr L7 Camera Assembly Replacement: 4 단계, 이미지 1/2 Motorola Slvr L7 Camera Assembly Replacement: 4 단계, 이미지 2/2
    • Remove the metal cover by inserting the flat end of the iFixit Opening Tool under the side of the cover, prying it away from the phone.
  5. Motorola Slvr L7 Camera Assembly Replacement: 5 단계, 이미지 1/2 Motorola Slvr L7 Camera Assembly Replacement: 5 단계, 이미지 2/2
    • Carefully separate the two connectors from their sockets on the motherboard using the flat end of the iFixit Opening Tool, so the two connectors are open.
  6. Motorola Slvr L7 Camera Assembly Replacement: 6 단계, 이미지 1/2 Motorola Slvr L7 Camera Assembly Replacement: 6 단계, 이미지 2/2
    • Use the flat end iFixit Opening Tool to pry the antenna cable connectors from their respective sockets on the motherboard.
    • Pull the antenna cable out to de-route it from the phone.
결론
Jorge Trujillo
회원 가입일: 05/19/11
520 평판
안내서 4개 작성하였습니다
CSU Los Angeles, Team 1-1, Nelson Spring 2011 CSU Los Angeles, Team 1-1, Nelson Spring 2011 회원
CSULA-NELSON-S11S1G1
2 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 2,997
